delay in receive event
In the CAN reading thread there is a loop which is waiting the Receive event.
I don't understand why there is a delay in the event ? , does it means that the event is generated only when the delay is passed ?
Re: delay in receive event
As we do not know which sample you are talking about, it is hart to say.
But using the Windows Event could be used for
- wait infinity until event is triggered
- wait for xx ms
The first version is used when you run a own simply receiving thread, the second one is using when you have a high layer protocol where you have "time outs"
For example sending a CAN Frame to the Bus - and need to get a reply from a other node within xx ms.
See PCAN-Basic Parameter Documentation page 49+
- wait for xx ms
Sorry I'm talking about the c# GUI sample that read and write to CAN.
OK - here the part (it is from the C++ BB sample) of the Thread:
As you could see - it use the "Infinite" Value
In C# /.Net it s handles like this
The Receive Event is here encapsulate in the -Net Framework (Namespace: System.Threading) see Windows .NET Specification for more info.
We need to use the Invoke function to interact with the User Interface.
DWORD TForm1::CANReadThreadFunc()
TPCANStatus stsResult;
DWORD result, dwTemp;
// Sets the handle of the Receive-Event.
stsResult = m_objPCANBasic->SetValue(m_PcanHandle, PCAN_RECEIVE_EVENT ,&m_hEvent, sizeof(m_hEvent));
// If it fails, a error message is shown
if (stsResult != PCAN_ERROR_OK)
::MessageBox(NULL, GetFormatedError(stsResult).c_str(), "Error!",MB_ICONERROR);
return 1;
// While this mode is selected
while(rdbEvent->Checked)
//Wait for CAN Data...
result = WaitForSingleObject(m_hEvent, INFINITE);
if (result == WAIT_OBJECT_0)
ReadMessages();
// Resets the Event-handle configuration
dwTemp = 0;
m_objPCANBasic->SetValue(m_PcanHandle, PCAN_RECEIVE_EVENT ,&dwTemp, sizeof(dwTemp));
return 0;
while (rdbEvent.Checked)
// Waiting for Receive-Event
if (m_ReceiveEvent.WaitOne(50))
// Process Receive-Event using .NET Invoke function
// in order to interact with Winforms UI (calling the
// function ReadMessages)
this.Invoke(m_ReadDelegate);
What is the meaning of the 50 in the c# sample.
I understand that the loop wait 50ms between each reading.
No it wait max. 50 ms if no Event comes up. But if a Event comes in within this 50ms it goes directly to the Read Function, if no event is triggered it calls every 50ms the read function
(for Status Messages etc. and to interact with the UI, not for real CAN Frames ) If CAN Messages come for example every 1 ms the Event is triggered every 1mS and do not wait the 50 ms.
Ok perfect thanks for this explanation.
I love your PCI board it works perfectly, and your sample are very usefull.
