send consecutive frame of SvcRequestDownload
Posted: Tue 15. Aug 2023, 01:32
by tomlee
When I send the service(UDSApi.SvcRequestDownload_2013) and get the response message(flow control frame):
18DA33F1 -  8    10 0B 34 00 44 00 01 00
18DAF133 -  8    30 00 00 00 00 00 00 00
but the service send the first frame only and it can not send consecutive frame:
18DA33F1 -  8    21 00 00 04 00 00 CC CC
What's the problem, please? thanks.
Re: send consecutive frame of SvcRequestDownload
Posted: Tue 15. Aug 2023, 09:51
by K.Wagner
could you please post your code when sending the service? Also it is good to know:
  • API version
  • If you are communicating with an ECU or if you are simulating it
Posted: Tue 15. Aug 2023, 11:27
by tomlee
Please check my code, thanks. ( PCAN-UDS 2.x API)
I am communicating with an ECU.
  	    // Define TimeOuts
            dw_buffer = CanTpApi.PCANTP_ISO_TIMEOUTS_15765_4;
            status = UDSApi.SetValue_2013(client_handle, uds_parameter.PUDS_PARAMETER_ISO_TIMEOUTS, ref dw_buffer, sizeof(UInt32));
            Console.WriteLine("=========Set ISO 15765-4 timeouts values: {0}", (int)status);
           // Define Network Address Information used for all the tests
            config.can_id = (UInt32)0xFFFFFFFF;
            config.can_msgtype = cantp_can_msgtype.PCANTP_CAN_MSGTYPE_EXTENDED;
            config.nai.protocol = uds_msgprotocol.PUDS_MSGPROTOCOL_ISO_15765_2_29B_FIXED_NORMAL;
            config.nai.target_type = cantp_isotp_addressing.PCANTP_ISOTP_ADDRESSING_PHYSICAL;
            config.type = uds_msgtype.PUDS_MSGTYPE_USDT;
            config.nai.source_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_TEST_EQUIPMENT; //0xF1
            config.nai.target_addr = (UInt16)uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_ECU_1; //0x33
            int MemoryStartAddress = 0x00010000;
            int MemorySize = 0x00040000;
            uds_msg request = new uds_msg();
            uds_msg response = new uds_msg();
            uds_msg confirmation = new uds_msg();
            byte[] lBufferMemAddr = BitConverter.GetBytes(startAddress).Reverse().ToArray();
            byte[] lBufferMemSize = BitConverter.GetBytes(dataLength).Reverse().ToArray();
            log.Info("*** UDS Service: RequestDownload ***");
            byte compressionMethod = 0x00; // No Compression
            byte encryptionMethod = 0x00; // No Encryption
            Console.WriteLine(); Console.WriteLine(); Console.WriteLine("*** UDS Service: RequestDownload ***");
            status = UDSApi.SvcRequestDownload_2013(channel, config, out request, 0x00, 0x00, lBufferMemAddr, (byte)lBufferMemAddr.Length, lBufferMemSize, (byte)lBufferMemSize.Length);
Posted: Wed 16. Aug 2023, 11:56
by F.Vergnaud
Here are changes made to your code so that we were able to successfully complete the UDS request:
In the following, the target address was 0x01 instead of 0x33:
            config.nai.target_addr = 0x33;  // uds_address.PUDS_ADDRESS_ISO_15765_4_ADDR_ECU_1 is actually 0x01
In the following, a variable "channel" was used instead of "client_handle":
            status = UDSApi.SvcRequestDownload_2013(client_handle, config, out request, 0x00, 0x00, lBufferMemAddr, (byte)lBufferMemAddr.Length, lBufferMemSize, (byte)lBufferMemSize.Length);
If the Consecutive frame is not sent by the API, this means that a network error may have occured. Please check:
1. the return status of the function SvcRequestDownload_2013,
2. the return status of the "wait for service" function (and in case of an error the network result of the request_confirmation):
            status = UDSApi.WaitForService_2013(client_handle, ref request, out response, out request_confirmation);
Also note that since you are configuring the API to check against OBD2 timeouts, be careful that the ECU must reply its FC frame before 75ms.
Posted: Wed 16. Aug 2023, 15:31
by tomlee
Hello, thank you for your help!
1) <the target address was 0x01 instead of 0x33”>
I've changed the content here :“PUDS_ADDRESS_ISO_15765_4_ADDR_ECU_1 = 0x33 ”
2) <a variable "channel" was used instead of "client_handle">
You are right. This is an error in the code I posted
3) I added the function code of of the function SvcRequestDownload_2013:
            if (UDSApi.StatusIsOk_2013(status))
                status = UDSApi.WaitForService_2013(channel, ref request, out response, out confirmation);
            Console.WriteLine(" UDS_SvcRequestDownload_2013: {0}", (int)status);
                display_uds_msg(ref confirmation, ref response, false);
            else
                display_uds_msg_request(ref request, false);
            // Free messages
            status = UDSApi.MsgFree_2013(ref request);
            Console.WriteLine(" Free request message: {0}", (int)status);
            status = UDSApi.MsgFree_2013(ref response);
            Console.WriteLine(" Free response message: {0}", (int)status);
            status = UDSApi.MsgFree_2013(ref confirmation);
            Console.WriteLine(" Free confirmation message: {0}", (int)status);
Program run result and he Consecutive frame is not sent by the API.
As shown below message:
11:01:09:0640 Rx 1 0x18DA33F1 x 8 10 0B 34 00 44 00 01 00
11:01:09:0644 Rx 1 0x18DAF133 x 8 30 10 05 FF 00 00 B2 00
11:01:09:0658 Rx 1 0x18DAF133 x 8 30 00 00 55 55 55 55 55
Console:
 UDS_SvcRequestDownload_2013: 654311424
UDS request from 0x00F1 (to 0x0033, with extension address 0x00) - result: 0 - OK !
-> Length: 11, Data= 34 00 44 00 01 00 00 00 04 00 00
 /!\ ERROR: NO UDS RESPONSE !!
 Free request message: 0
 Free response message: 0
 Free confirmation message: 0
4) If I add code of "PCANBasic.Write(PCANBasic.PCAN_USBBUS1, ref CANMsg)" to send Consecutive frame, then the ECU can give positive feedback.
Posted: Wed 16. Aug 2023, 16:35
by F.Vergnaud
Please check you are using the latest version of PCAN-ISO-TP: v3.4.0 or later.
Your ECU sends a Flow Control frame with a non constant padding value which was considered as an invalid ISOTP FC frame prior v3.3 (see https://www.peak-system.com/PCAN-ISO-TP ... .html?&L=1).
This feature is disabled by default on v3.3+.
You can see that the returned status is 654311424 => 0x27000000 which is PUDS_STATUS_SERVICE_TX_ERROR: an error occured during the transmission of the ISOTP message.
You could get more information by checking the ISOTP network result in "request_confirmation.msg.Msgdata_any_Copy.netstatus".
Posted: Wed 16. Aug 2023, 17:13
by tomlee
You are right. It's OK now! Thanks!
Posted: Thu 17. Aug 2023, 07:57
Topic closed
