Tx Self-Acknowledge for PCAN-USB?
USB to CAN Interface
nurber
Post by nurber » Mon 4. Sep 2023, 02:48
Hi Forum. To confirm I should be able to set "Tx Self-Acknowledge" in PCAN-View 5.1.0.887 with same model IPEH-002021 dongle as original poster using driver 4.4.0 and firmware 8.6.1 ?
Thanks, Sven
Reason: Changed subject of topic that was split from another topic.
Re: Tx Self-Acknowledge for PCAN-USB?
Post by G.Lang » Mon 4. Sep 2023, 07:21
Dear Sven,
the PCAN-USB device with the part number IPEH-002021 [and IPEH-002022) don´t support the "Tx Self-Acknowledge" feature.
Best regards
Post by PEAK-Support » Mon 4. Dec 2023, 09:40
See Documentation of the Software (PCAN-View, PCAN-Basic API etc.)
Tx Self-Acknowledge
If activated, the CAN controller sends an Acknowledge slot (ACK) on the bus even as sender, so that no other CAN nodes must be present on the bus to acknowledge the frame.
Requires at least PCAN driver version 4.3.0 and the CAN interface used or its firmware version must support the feature.
Post by G.Lang » Mon 4. Dec 2023, 09:43
The "TX Self-Acknowlegde"-Feature require a CAN-FD capable hardware.
