problem building peak linux driver
olivier_subatech
Post by olivier_subatech » Tue 14. Nov 2023, 13:51
Hi there,
I can't manage to build the peak linux driver.
Can you please help me on this one ?
below, the output of the make command :
make[1]: Entering directory '/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver'
*** Host OS Release=Fedora Linux v38
*** Host machine kernel version=6.5.10-200.fc38.x86_64
*** Driver kernel version=6.5.10-200.fc38.x86_64 (6.5.10)
*** Path to kernel sources=/lib/modules/6.5.10-200.fc38.x86_64/build
*** use KBUILD=yes
*** use DKMS=
*** gcc version=13
make -C /lib/modules/6.5.10-200.fc38.x86_64/build  EXTRA_CFLAGS="-I/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DNO_DONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT   -Wno-date-time" V=0 modules M=/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver
make[2]: Entering directory '/usr/src/kernels/6.5.10-200.fc38.x86_64'
  CC [M]  /home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.o
In file included from ./include/linux/kobject.h:20,
                 from ./include/linux/module.h:21,
                 from /home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_common.h:48,
                 from /home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:36:
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3506:22: error: initialization of ‘ssize_t (*)(const struct class *, const struct class_attribute *, char *)’ {aka ‘long int (*)(const struct class *, const struct class_attribute *, char *)’} from incompatible pointer type ‘ssize_t (*)(struct class *, struct class_attribute *, char *)’ {aka ‘long int (*)(struct class *, struct class_attribute *, char *)’} [-Werror=incompatible-pointer-types]
 3506 | static CLASS_ATTR_RO(version);
./include/linux/sysfs.h:117:19: note: in definition of macro ‘__ATTR_RO’
  117 |         .show   = _name##_show,                                         \
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3506:8: note: in expansion of macro ‘CLASS_ATTR_RO’
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3506:22: note: (near initialization for ‘class_attr_version.show’)
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3507:22: error: initialization of ‘ssize_t (*)(const struct class *, const struct class_attribute *, char *)’ {aka ‘long int (*)(const struct class *, const struct class_attribute *, char *)’} from incompatible pointer type ‘ssize_t (*)(struct class *, struct class_attribute *, char *)’ {aka ‘long int (*)(struct class *, struct class_attribute *, char *)’} [-Werror=incompatible-pointer-types]
 3507 | static CLASS_ATTR_RO(clk_ref);
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3507:8: note: in expansion of macro ‘CLASS_ATTR_RO’
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3507:22: note: (near initialization for ‘class_attr_clk_ref.show’)
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c: In function ‘init_module’:
/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.c:4813:9: warning: ignoring return value of ‘class_register’ declared with attribute ‘warn_unused_result’ [-Wunused-result]
 4813 |         class_register(&pcan_class);
cc1: some warnings being treated as errors
make[4]: *** [scripts/Makefile.build:243: /home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver/src/pcan_main.o] Error 1
make[3]: *** [/usr/src/kernels/6.5.10-200.fc38.x86_64/Makefile:2046: /home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver] Error 2
make[2]: *** [Makefile:246: __sub-make] Error 2
make[2]: Leaving directory '/usr/src/kernels/6.5.10-200.fc38.x86_64'
make[1]: *** [Makefile:523: all] Error 2
make[1]: Leaving directory '/home/lemaire/code/pcan/peak-linux-driver-8.16.0/driver'
make: *** [Makefile:84: all] Error 2
Re: problem building peak linux driver
Post by M.Maidhof » Tue 14. Nov 2023, 13:58
please send an email to our support email address telling us the serial number of your PCAN hardware. You need a patch for using the peak-linux-driver-8.16 with such a recent kernel version 6.5.x.
olivier_subatech
Post by olivier_subatech » Tue 14. Nov 2023, 14:05
Hi Michael,
Thank you very for your help.
Just a stupid question. Do I need to install the driver if I want to use the pcan ethernet gateway DR or I may be able to communicate with the gateway using simple Linux TCP socket ?
Many thanks for your help.
Olivier
Last edited by olivier_subatech on Tue 14. Nov 2023, 14:10, edited 1 time in total.
Post by M.Maidhof » Tue 14. Nov 2023, 14:10
Hi Olivier,
the PCAN-Ethernet Gateway is not supported by our peak-linux-driver. In that case you don't need that driver at all. You can use Linux sockets to communicate with the PCAN-Ethernet Gateway. See Developer Documentation for more details:
https://www.peak-system.com/produktcd/P ... on_eng.pdf
olivier_subatech
Post by olivier_subatech » Tue 14. Nov 2023, 14:17
Thank you for your answer.
YoanEyeLights
Post by YoanEyeLights » Fri 12. Jan 2024, 17:41
Hi Michael, here we have the same issue, could you please share the patch to let us compile the peak-linux-driver-8.16.0 driver ?
We want to use the PCAN basic API with Python.
You'll find below some commands if it could help you to debug.
make
make[1] : on entre dans le répertoire « /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver »
*** Host OS Release=Ubuntu v22.04
*** Host machine kernel version=6.5.0-14-generic
*** Driver kernel version=6.5.0-14-generic (6.5.0)
*** Path to kernel sources=/usr/src/linux-headers-6.5.0-14-generic
*** use KBUILD=yes
*** use DKMS=
*** gcc version=12
make -C /usr/src/linux-headers-6.5.0-14-generic  EXTRA_CFLAGS="-I/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DNO_DONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT   -Wno-date-time" V=0 modules M=/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver
make[2] : on entre dans le répertoire « /usr/src/linux-headers-6.5.0-14-generic »
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
  You are using:           gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
  CC [M]  /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.o
                 from /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_common.h:48,
                 from /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:36:
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3506:22: error: initialization of ‘ssize_t (*)(const struct class *, const struct class_attribute *, char *)’ {aka ‘long int (*)(const struct class *, const struct class_attribute *, char *)’} from incompatible pointer type ‘ssize_t (*)(struct class *, struct class_attribute *, char *)’ {aka ‘long int (*)(struct class *, struct class_attribute *, char *)’} [-Werror=incompatible-pointer-types]
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3506:8: note: in expansion of macro ‘CLASS_ATTR_RO’
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3506:22: note: (near initialization for ‘class_attr_version.show’)
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3507:22: error: initialization of ‘ssize_t (*)(const struct class *, const struct class_attribute *, char *)’ {aka ‘long int (*)(const struct class *, const struct class_attribute *, char *)’} from incompatible pointer type ‘ssize_t (*)(struct class *, struct class_attribute *, char *)’ {aka ‘long int (*)(struct class *, struct class_attribute *, char *)’} [-Werror=incompatible-pointer-types]
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3507:8: note: in expansion of macro ‘CLASS_ATTR_RO’
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:3507:22: note: (near initialization for ‘class_attr_clk_ref.show’)
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c: In function ‘init_module’:
/home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.c:4813:9: warning: ignoring return value of ‘class_register’ declared with attribute ‘warn_unused_result’ [-Wunused-result]
make[4]: *** [scripts/Makefile.build:251 : /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver/src/pcan_main.o] Erreur 1
make[3]: *** [/usr/src/linux-headers-6.5.0-14-generic/Makefile:2037 : /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver] Erreur 2
make[2]: *** [Makefile:234 : __sub-make] Erreur 2
make[2] : on quitte le répertoire « /usr/src/linux-headers-6.5.0-14-generic »
make[1]: *** [Makefile:523 : all] Erreur 2
make[1] : on quitte le répertoire « /home/utilisateur/Téléchargements/peak-linux-driver-8.16.0/driver »
make: *** [Makefile:84 : all] Erreur 2
uname -a
Linux utilisateur-Inspiron-14-5420 6.5.0-14-generic #14~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Nov 20 18:15:30 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
uname -r
6.5.0-14-generic
Thanks in advance !
Yoan
F.Albers
Post by F.Albers » Mon 15. Jan 2024, 09:55
I'm running into exactly the same issue as YoanEyeLights after updating to the 6.5 kernel.
Could you pelase send me the patch as well (or make it publicly available, since it will most likely affect more people after the update to the 6.5 kernel was recently released)?
Thanks in advance and best regards,
Franz
Post by PEAK-Support » Fri 19. Jan 2024, 09:23
*** Update ***
The problem is fixed, and the driver is released and could be download from the Linux page.
! Topic closed !
