PCAN-UDS
Ken0711
PCAN-UDS
Post by Ken0711 » Thu 30. Nov 2023, 08:10
Good Morning PCan Support,
I developed a Flash tool depend on pcan UDS ,and i used pcan USB ,it work normally ,but when i changed to the kvaser
the Hardware would't initialize ,and then i used the Pcan view also wouldn't connect the kvaser
I knew something i missed ,so please give me some advises how to solved it ?
thanks!
** ADMIN : changed Titel to be readable / move to correct topic ** PLEASE check the forum rules before you post !!
Re: Pcan UDS de
Post by PEAK-Support » Thu 30. Nov 2023, 08:19
You missed that the API and Driver, all the Tools etc. from PEAK-System are (c) protected and work only with original PEAK-System Products. You own for every single PCAN-USB one license that you could use with this Adapter.
See License Information / Eula etc. (Which, by the way, have accept when installing Drivers / DLLs!) If you use a KVaser or any other non PEAK-System CAN Interface, you need to use their API Interface (if they have some).
Our APIs / Software Tools only work with our CAN Interfaces and are protected against using with other Vendors Hardware.
(by the way - why should we support with our Tools / APIs etc., that you could download from our WEB page for no extra cost, other companies Hardware ?...think about it...)
