Alternative way to trigger sending messages than message gateway
Posted: Fri 26. Jan 2024, 11:05
by SamIO
Using the PCAN-Router pro, I need to return messages after receiving a RTR with a different ID. I currently am using the "Message gateway" to trigger sending the message. E.g. I receive a remote frame on ID 0x5000Ah and I want to respond on ID 0xAh.
This triggering is working well but the problem is that it seems that the amount of "message gateway"s is limited to 120. I need about double that amount. Is there an alternative way of triggering messages or something similar? Or expand the limit?
Thank you in advance.
Re: Alternative way to trigger sending messages than message gateway
Posted: Fri 26. Jan 2024, 13:01
The Mesage Limit is a fixed value in the firmware and could not be changed with limited other ressources.
