TPCANTimestamp into readable time
Posted: Thu 22. Feb 2024, 15:01
by KRotmann
Hello!
For a current project, I need to read data from CAN using Labview. I am using the kdi_labview_api_for_pcan_basic_fd-1.0.0.10 1 and Labview Version Q3 2023 (32-bit).
So far, I've established a connection and am able to read CAN Data via the Function "CAN Read". The Code returns the CAN messages, but also the TPCANTimestamp out.
The question is, how do I convert the type TPCANTimestamp (e.g. 30F0000 06F4 7D60) into UTC time (with Labview)?
From the following entries in the form we figured out one could use the following formula to convert the timestamp into milliseconds:
viewtopic.php?f=119&t=2529&p=7503&hilit=timestamp#p7503
viewtopic.php?t=3223
int32 millis: --> 30F0000
int16 millis_overflow; --> 06F4
int16 micros; -->7D60
time_milliseconds = micros + 1000 * millis + 0x100000000 * 1000 * millis_overflow
Using this formula, we get weird results (e.g. negative numbers), and we don't know how to convert these milliseconds into a readable time, e.g. UTC.
Any help would be great!
Kirsten
PS: In the attachment an Output of the Example PCAN_BASIC_READ_EXAMPLE from the APi.
Re: TPCANTimestamp into readable time
Posted: Thu 22. Feb 2024, 15:48
please see info in the help of PCANBasic API. The time-stamp contains the number of microseconds since the start of Windows. There is no relation to the UTC time.
Take care that all these struct values are unsigned values, without negative numbers:
public value struct TPCANTimestamp
    UInt32 millis;
    UInt16 millis_overflow;
    UInt16 micros;
Posted: Fri 23. Feb 2024, 10:22
by KRotmann
Hello Michael,
thank you very much for the reply!
I have another question: In comparison to PCAN Exlorer, time is displayed either relative (how many ms have passed since the start of recording CAN) or in absolute time (Compare images below).
Is there any possibility to display the time analogically in Labview, and if yes, how?
Posted: Fri 23. Feb 2024, 11:23
you have to do this in your application. You need to get the UTC time when the first frames was received, and use the timestamp from the first message as an offset for the future timings in UTC time. So this is just programming, nothing to do with our API or LabView. As we don't use LabView, we can't tell you how to manage this with this tool.
