Reset PCAN-USB initialized state by software
eriks
Post by eriks » Fri 22. Mar 2024, 09:40
There used to be an option in the PeakCPL to reset PCAN-USB: viewtopic.php?f=41&t=2893&p=9996#p9996
But since that is not available anymore I'm wondering how to reset the PCAN-USB now. In the new PEAK Settings I cannot find it.
I'm stuck in PCAN_ERROR_HWINUSE and have to reset the pc now if that happens which is quite annoying.
Erik
Re: Reset PCAN-USB initialized state by software
Post by M.Maidhof » Fri 22. Mar 2024, 09:51
there is an option now in PEAK Settings to close "zombi" PCANBasic clients. This option will only be visible when there is a PCANBasic client active:
Post by K.Wagner » Fri 22. Mar 2024, 10:03
please note following things:
  1. The PEAK-Settings only shows PCAN-Basic "active" connections. If there are none, then you do not see this section in the app.
  2. If you do not see this section in the App, but you cannot connect to the channel, this is mostly because the channel is occupied by another applicaiton (PCAN-View, PCAN-Explorer, or any other applicaiton using the PCAN-Developer a.k.a CanApi2/4)
The PCAN-Basic section in the PEAK-Settings App looks as follow:
eriks
Post by eriks » Fri 22. Mar 2024, 11:44
Ah ok, I see. Indeed when I have an application open that uses pcanbasic I see the option.
Only issue I now have is when I have the PCAN_ERROR_HWINUSE error I don't see that option, although I am only testing our application that uses pcanbasic. Only option is to reset the pc then. I will investigate a bit further.
Thanx for your explanation.
Erik
Post by M.Maidhof » Fri 22. Mar 2024, 13:11
looks like another application is active (could also using a different API). Do you see PCAN-USB LED flashing in that moment? Do you use codesys or a similar product? Check taskmanager for such applications, and remove the autostart of such apps.
You could also contact us by email (support) to send you a tool to check your PC for installed PCAN files.
