Unbuntu Remove ALL PEAK everything -- how?
Posted: Wed 15. May 2024, 23:02
by rknapp
The presence of PEAK drivers/? on this unbuntu laptop is causing me a TON of problems. (Things work OK on my Windows laptop, but on this machine, I've never been able to get the Peak dongle to work. I can stick with the Windows machine.) How can I please remove all PEAK everything from this machine? The errors below cause failures in other installation scripts which I've ignored for a while, but are now a real problem as I need to install some other stuff.
Please don't say "navigate to where they are and delete them" as I'm too dumb to know where they are, unless you please help me find them or point to exactly where they are. This is Ubuntu Focal, by the way.
~~ Robert
<pre><font color="#4E9A06"><b>rknapp@rknapp-Precision-7510</b></font>:<font color="#3465A4"><b>~</b></font>$ sudo apt update &amp;&amp; sudo apt upgrade -y
[sudo] password for rknapp:
Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Get:1 https://packages.microsoft.com/repos/code stable InRelease [3,590 B] <font color="#C4A000"> </font>
Hit:4 http://security.ubuntu.com/ubuntu focal-security InRelease <font color="#C4A000"> </font>
Hit:5 http://ppa.launchpad.net/ansible/ansible/ubuntu focal InRelease <font color="#C4A000"> </font>
Hit:6 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease<font color="#C4A000"> </font>
Get:7 http://www.peak-system.com/debian focal InRelease [8,493 B]
Err:7 http://www.peak-system.com/debian focal InRelease
The following signatures couldn&apos;t be verified because the public key is not available: NO_PUBKEY DE0B8CB39CEAA78D
Reading package lists... Done
<font color="#C4A000"><b>W: </b></font>GPG error: http://www.peak-system.com/debian focal InRelease: The following signatures couldn&apos;t be verified because the public key is not available: NO_PUBKEY DE0B8CB39CEAA78D
<font color="#CC0000"><b>E: </b></font>The repository &apos;http://www.peak-system.com/debian focal InRelease&apos; is not signed.
<font color="#C4A000">N: </font>Updating from such a repository can&apos;t be done securely, and is therefore disabled by default.
<font color="#C4A000">N: </font>See apt-secure(8) manpage for repository creation and user configuration details.
</pre>
Re: Unbuntu Remove ALL PEAK everything -- how?
Posted: Thu 16. May 2024, 15:55
by S.Grosjean
It looks like you installed the pcanview package in the past. So, first you have to remove it, if it is still present:
$ sudo dpkg -P pcanview-ncurses
Then, to get rid of these messages, please type:
$ sudo rm -f /etc/apt/sources.list.d/peak-system.list
Finally, you can do:
$ sudo apt update
to check if everything is back to normal...
Posted: Thu 16. May 2024, 19:47
by rknapp
Stephane,
Thanks so much for your attention to this problem! YOUR PLAN WORKED PERFECTLY.
Now, when I tried sudo dpkg -P pcanview-ncurses
dpkg: warning: ignoring request to remove pcanview-ncurses which isn't installed
However, there was no comment re:
And -- a sudo apt update confirmed that all was well. This laptop is back to health.
So I want to thank you again, very much,
~~ Robert
Posted: Wed 22. May 2024, 04:20
Thank you for the Feedback - Topic closed -
