PCAN-View: order of received messages
Posted: Fri 7. Dec 2012, 14:17
by A.Kapp
sometimes the order of listed CAN messages does not comply with the timestamp (cf. attached trace).
- Is this a problem of the hardware or the software PCAN-View?
Hardware: PCAN USB-adapter with firmware 2.8
I kind of remember having read about ordering problems, but I do not remember if this was a problem of PCAN-View, PCANBasic.dll or the hardware driver.
Kind regards,
Andreas
Re: PCAN-View: order of received messages
Posted: Fri 7. Dec 2012, 16:34
the timestamps you will see in PCAN-View are based on our driver and on the SystemTicks of Windows. Are there other applications beside PCAN-View running on the same internal PEAK network and transmitting frames?
Which driver version pcan_usb.sys is used?
Posted: Mon 10. Dec 2012, 10:12
by A.Kapp
you are right, it might be a Windows issue.
PCAN-View is just used to monitor CAN traffic. The CAN network is as follows
- Hardware: PC with PEAK PCAN-USB adapter
- application software: Python script running a self-written DLL (C++) using PCANBasic.dll
(just a testbed; in the "real" application the DLL will be used in another C++ program)
- application running on DSPs answering the queries issued by the application software
Up to now I used PCAN-API version 1.1.0.26. Right now I have repeated the experiment using PCAN-API version 1.2.1.31.
So far I have not received this strange PCAN-View behaviour any more.
Is the reported PCAN-View behaviour (weird order of received messages) related to an outdated PCAN-API?
Up to now I thought that PCAN-View is just a CAN traffic sniffer that is
independent of the application software (including PCAN-API) sending CAN messages.
Andreas
Posted: Mon 10. Dec 2012, 15:26
the timestamps are generated by the hardware and driver, so I need to know which driver version pcan_usb.sys you are using (will be displayed in PCAN-View help menu). Please don“t mix up driver version with API or dll version. When you are using the PCANBasic API, you should use the latest version 1.2.3.34.
best regards
Posted: Tue 31. May 2016, 13:48
by LudoG
I reactivate this thread because I have the same problem.
6 frames are sent by an ECU (connected directly with PCAN USB, no other device on the network).
The order of the frames seen by PCAN View is often wrong. See the attached trace rx_order_swapped.trc: the last 2 frames are swapped.
Moreover the display is sometimes not consistent with the time stamps. See rx_order_unsorted_time.trc: notice the last frame whose time stamp is actually lower than the frames before.
The same happens when using my own application interfacing with PCAN Basic DLL (this is the way I noticed the problem the first time).
The order of the frames was checked by adding another device on the network (from a well-known of your competitors) and it was correct.
Here are the HW/SW references:
PCAN USB IPEH-002021 133832
firmware 2.8
pcan_usb.sys 4.0.18.15889
pcan_basic.dll 4.0.4.88
PCAN View 4.0.31.444
(64-bit system, but 32-bit applications)
Are there any troubles already reported for these product versions?
Thanks in advance.
Ludovic
Posted: Tue 31. May 2016, 16:02
regarding the swapped timestamp, please check if you use an USB 3 hostcontroller with old chipset drivers:
http://www.peak-system.com/forum/viewto ... ?f=7&t=191
When you have a PCANBasic API application running with PCAN-View at the same time, the transmitted messages of your application will be faster in the trace of PCAN-View than on the real CAN bus. This is because of the internal connection of PCAN-View to the driver interface. An external device will see those messages in the correct order, just test it with another PCAN-USB on your CAN network.
