MicroMod Digital 2 CAN in to High side output
Posted: Fri 5. Jul 2024, 12:19
by Gelby
Hello all,
new to MicroMod devices, I need to activate one High side output depending on the value of two bits of one byte of a CAN received message ( for instance, if I receive a CAN message with byte 0 value 0x03 I activate one High side output, if the byte 0 value is 0x00, 0x01 or 0x02 I deactivate the output).
I read the programming software documentation and I learned how to do this only by evaluating one bit in one byte, but I need to evaluate two bits in a byte.
Please help me.
Thanks in advance
Re: MicroMod Digital 2 CAN in to High side output
Posted: Fri 5. Jul 2024, 15:21
by M.Heidemann
One option would be to use the PWM function,
you can use scale and offset to get your intended results,
here a screenshot of an example of a low-side driver being
used to mirror your application:
2024-07-05 14_59_50-Frequenzout_mit_offset.mcfx - PCAN-MicroMod Configuration.png
2024-07-05 14_59_50-Frequenzout_mit_offset.mcfx - PCAN-MicroMod Configuration.png (20 KiB) Viewed 12505 times
Alternatively you could feed back Outputs you switch with your message and then use the Digital Function to switch your intended output:
In your case you would use an AND function
your two bits both need to be 1 to trigger the output,
so logically this means:
0x00
bit0 = 0
bit1 = 0_____> False = No Output
0x01
Bit0 = 0
Bit1 = 1_____> False = No Output
0x02
Bit0 = 1
Bit1 = 0_____> False = No Output
0x03
Bit0 = 1
Bit1 = 1_____> True = Switch Output
Digital function.png (48.15 KiB) Viewed 12505 times
Please let me know if you were able to use one of the methods successfully.
Posted: Fri 5. Jul 2024, 16:17
by Gelby
Hello Marvin,
thanks for you reply, I think to try the second option, anyway, what is unclear to me is the association between the 2 bits in the CAN input message and the Digital Output.
I mean, in your digital function, I see an logic AND operation between Digital Input 0 and Digital Input 1, but I need the logic AND between bit 0 and bit 1 of the byte zero of a particular CAN input message, could you explain this connection better? Where this association take part?
Thank you
Posted: Fri 5. Jul 2024, 16:28
by M.Heidemann
Sure, let me explain this a bit further:
You use two DOuts that act as a stand in for your bits on the byte of your CAN-ID you want to use to switch the High-Side Dout.
So you define two Douts:
Dout #1:
Your incoming CAN-ID
Start Byte 0
Start Bit 0
Power-Up Value 1
Dout #2:
Your incoming CAN-ID (Same as for Dout#1)
Start Byte 0
Start Bit 1
Power-Up Value 1
Bit0 & bit1 will only be 1 if the incoming message is at least 0x03h, so in this case
you can feed them back into the inputs and use the logic function with AND, as showcased before.
Posted: Fri 5. Jul 2024, 16:45
by Gelby
Dear Marvin,
now it is more clear to me and make sense, as soon as I will give it a try, I will give you a feedback.
