Macro to summarise content from several messages
Posted: Fri 14. Dec 2012, 20:47
by PCANUser
We are using PCAN Explorer 5 to display a panel that shows various parameters from our device. One of the fields in the CAN message is a fault ID. If more than one fault is present the message cycles round each of the faults in turn, one at a time.
What I would like to be able to do is order the fault codes and display the associated fault text for each fault code in the panel.
I have made the basics work using a macro by writing the information to a label but I have several questions:
1. The messages are coming at 5ms intervals. VBScript seems to be struggling to keep up. Is a plug-in a possible alternative? Is there any guidance about writing a plug-in using C# for example? Can a plug-in access a component on a panel?
2. There are quite a lot of components on the panel. Is there a way to change the rate at which the panel updates (i.e. make it update slower) independently of the rate at which the messages are being received?
3. Is it possible to make a macro run automatically when a panel is loaded?
Thanks in advance for your help.
Richard
Re: Macro to summarise content from several messages
Posted: Tue 18. Dec 2012, 11:17
by K.Wolf
1. I believe the overhead of writing an Add-in is not justified here. Yes, Add-ins can access panel components. But displaying values e.g. in a Label can only be done in the same way as in a VBS macro, by setting the value of the signal that is assigned to a Label. You cannot set the Label caption directly.
Perhaps the solution to your problem is to set up a separate Client as demonstrated in the WaitForID100 example macro, specifying a filter that exactly matches the CAN-ID of the message containing the fault ID. In this way, you would not miss any fault IDs, all relevant messages are buffered in the receive queue of the separate client.
Your macro simply reads all the messages from the queue and processes the fault IDs one by one. But you would have to decode the fault IDs yourself from the message's raw data bytes. I made a short test with a 1 ms message, absolutly no performance problem here.
2. At the moment there is no way to control the update speed of a panel. If you use CAN-based signals in your panel, every received message updates the corresponding component immediately. You could use virtual signals for some components in the panel that are updated most often, and control updating of these signals in your macro in a slower rate, for example.
3. No, you can only run a macro automatically when a project is loaded. See the "Post Load Command" property in the Project properties.
Posted: Mon 14. Jan 2013, 13:00
by PCANUser
Thanks for the response. I am confused by your reference to the WaitForID100 example macro. Where would I find it? I can't find it anywhere in my installation and a search of your web site also turns up no hits.
I assume you are referring to a sample macro that calls the WaitId method.
Richard
Posted: Mon 14. Jan 2013, 13:03
by PCANUser
I just found it. For anybody else searching for this it lives in the Sample.pem macro file.
Posted: Mon 14. Jan 2013, 13:07
Yes, in the sample.pem are a lot of sample functions implemented. Here the code of the current version:
(14th of January 2013)
'FILE DESCRIPTION: Test and sample macros
Sub EnumDocuments()
'DESCRIPTION: Displays all open documents
PrintToOutputWindow peVBSMacro
Dim doc
For Each doc In Documents
PrintToOutputWindow doc.FullName
Next
End Sub
Sub EnumWindows()
'DESCRIPTION: Displays all open windows
Dim win
For Each win In Windows
PrintToOutputWindow win.Caption
Next
End Sub
Sub SendMail()
'DESCRIPTION: Sends a test E-Mail to PEAK-System
Dim outlook
On Error Resume Next
Set outlook = CreateObject("Outlook.Application")
If outlook Is Nothing Then
MsgBox "Microsoft Outlook is not installed!",,"SendMail"
Exit Sub
End If
On Error GoTo 0
Dim mail
Dim outbox
Dim mapi
Dim recipient
Dim address
address = "support@peak-system.com"
address = InputBox("Send a test E-Mail to:", "SendMail", address)
If address = "" Then
Exit Sub
End If
Set mapi = outlook.GetNameSpace("MAPI")
Set outbox = mapi.GetDefaultFolder(4)
Set mail = outbox.Items.Add(0)
Set recipient = mail.Recipients.Add("support@peak-system.com")
recipient.Type = 1
mail.Subject = "Test"
mail.Body = "This is a PCAN-Explorer 5 macro test."
mail.Send
End Sub
Sub CreateOutputPane()
'DESCRIPTION: Creates a new pane in the Output window
Dim win
Dim OutputWin
Dim pane
Set win = Windows(peWindowKindOutput)
win.IsVisible = True
Set OutputWin = win.Object
Set pane = OutputWin.OutputWindowPanes("My pane")
If pane Is Nothing Then
Set pane = OutputWin.OutputWindowPanes.Add("My pane")
End If
pane.Activate 'Make pane visible
pane.OutputString("This is a text" & vbCrLf)
End Sub
Sub NewClientSend()
'DESCRIPTION: Sends CAN messages using a new PCAN client
Dim UseConn, conn
' Find the first enabled connection in the project that uses the CAN protocol
Set UseConn = Nothing
For Each conn In Connections
If conn.IsEnabled And conn.Protocol = peProtocolCAN Then
Set UseConn = conn
Exit For
End If
Next
If UseConn Is Nothing Then
MsgBox "Project does not contain any enabled CAN connections"
Exit Sub
End If
' Create a new client and connect it to the same Net that the
' found connection uses
Dim MyClient, PcanConn
Set MyClient = CreateObject("PCAN3.PCANClient")
MyClient.Device = UseConn.Device
MyClient.Name = "Macro"
Set PcanConn = MyClient.Connections.Add(UseConn.CommunicationObject.NetName)
' Now create and initialize a new transmit message
Dim msg
Set msg = MyClient.Messages.Add
timestamp = MyClient.GetSystemTime + 1000
With msg
.ID = &H100
.DLC = 4
.MsgType = pcanMsgTypeExtended
.Data(0) = &H11
.Data(1) = &H22
.Data(2) = &H33
End With
for i = 1 To 20
msg.Data(3) = i
msg.Write PcanConn, timestamp
timestamp = timestamp + 500
next
' Wait until all messages have been sent before finishing macro,
' since this would terminate the client and delete all messages
' that are still in the queue
While not MyClient.XmtQueueEmpty
Wait 500
Wend
Wait 500
End Sub
Sub WaitForID100()
'DESCRIPTION: Waits until CAN-ID 100h is received
' To view the output messages of this macro, open the Output Window and
' select the "Macro" tab
Dim UseConn, conn
Set UseConn = conn
Exit For
End If
Next
Exit Sub
End If
PcanConn.RegisterMsg &H100, &H200, False, False
i = 0
Dim RcvMsg
Set RcvMsg = MyClient.Messages.Add
Do
Do While not RcvMsg.Read
' Wait for a received message
Loop
If RcvMsg.LastError = pcanErrorOk Then
PrintToOutputWindow "Received !"
i = i + 1
End IF
Loop While RcvMsg.ID <> &H100
PrintToOutputWindow "Finished, " & CStr(i) & " messages received !"
End Sub
Sub LosslessTrace()
'DESCRIPTION: Traces messages without losses and stores the data in multiple trace files
' Modify as required
const DefaultDestDir = "c:\Trace"
const DefaultConnection = "TestNet@pcan_pci"
const MessagesPerTracer = 100000
' Explicit Variable declarations
Dim CurrentTracer, NextTracer
Dim doc, wnd
Dim TracerNumber, NewTop
Dim IsRunning
Dim DestDir, Connection
' Prompt for the destination directory
DestDir = InputBox("Destination Directory:", "LosslessTrace", DefaultDestDir)
If DestDir = "" Then Exit Sub
' Make sure the selected directory exists
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
If Not fso.FolderExists(DestDir) Then
MsgBox "The selected directory does not exist!",,"LosslessTrace"
Exit Sub
End If
Set NextTracer = Nothing
IsRunning = True
TracerNumber = 0
NewTop = 250
If ActiveProject Is Nothing Then
' Create and configure a new project
NewProject "LoslessTrace", ""
' Prompt for connection
Connection = InputBox("Select Connection:", "LosslessTrace", DefaultConnection)
Dim conn
Set conn = Connections.Add(Connection)
conn.IsEnabled = True
If Not conn.IsEnabled Then
MsgBox "Error while enabling the connection!",,"LosslessTrace"
Exit Sub
End If
End If
Set doc = Documents.Add(peDocumentKindTrace)
Set wnd = doc.ActiveWindow
wnd.Left = 0
wnd.Top = 0
wnd.Height = 250
wnd.Width = 500
Set CurrentTracer = wnd.Object.Tracer
CurrentTracer.BufferType = peTraceBufferTypeLinear
CurrentTracer.BufferSize = MessagesPerTracer
CurrentTracer.Start
Do While IsRunning
' Tracer records data until the filling level reaches 95%
Do While IsRunning And (CurrentTracer.FillingLevel < 95)
' Prepare next tracer at a filling level of 90%
If (NextTracer Is Nothing) And (CurrentTracer.FillingLevel > 90) Then
' Arrange new tracer window
wnd.Left = 0
wnd.Top = NewTop
wnd.Height = 250
wnd.Width = 500
if (NewTop = 0) Then
NewTop = 250
Else
NewTop = 0
End If
Set NextTracer = wnd.Object.Tracer
NextTracer.BufferType = peTraceBufferTypeLinear
NextTracer.BufferSize = MessagesPerTracer
End If
Wait 50
IsRunning = CurrentTracer.TraceState = peTraceStarted
Loop
If IsRunning Then
NextTracer.Start
CurrentTracer.Stop
End If
' Save data of current tracer
If CurrentTracer.FillingLevel > 0 Then
TracerNumber = TracerNumber + 1
CurrentTracer.Document.Save DestDir & "\Trace" & TracerNumber & ".trc"
' Wait until data is saved
Do While CurrentTracer.TraceState = peTraceSaving
Wait 10
Loop
Wait 100
End If
' Close old tracer window
CurrentTracer.Document.Close peSaveChangesNo
Set CurrentTracer = NextTracer
Loop
End Sub
