Issues with trace recording
alessandrop
Post by alessandrop » Thu 28. Nov 2024, 15:59
Hello PEAK-Support Team,
I'm using a PCAN-Router Pro FD exploiting the "ready-to-use firmware for tracing CAN data" mentioned in the user manual, and I've some questions.
The manual states that if TRC_MODE=2 in the config.txt file, the circular-append option should be set, implying that:
  • If a new recording is started, existing trace files are kept.
  • If the memory's maximum capacity is reached, the oldest file is deleted and a new file with an incremented file index is created.
Unfortunately, I'm not able to replicate such a feature. Figure "Issue_1" shows a case in which the device is powered ON, the Wake-up signal is ON, two traces are normally recorded, then at some point during the record of the third trace the memory card becames full, subsequently several 0 kB traces are stored. The device doesn't delete the old files to replace them with new ones. Sometimes, I'm able to obtain the expected behaviour retriggering the Wake-Up signal (ON-->OFF-->ON), but the new file doesn't have an incremented index and it doesn't happen all the times.
Moreover, I found also the following two issues:
  • Assume that the device is powered ON, the Wake-up signal is ON, and the CAN traffic is ON. At some point, both the CAN traffic and the Wake-up signal go OFF, then some extra short (each 5 s long, like the parameter TRC_STOP_T15_TO) traces are recorded. Please, see figure "Issue_2", in this test such a phenomenon happened two times.
  • Assume that the device is powered ON, the Wake-up signal is OFF, and the CAN traffic is ON. In this case, short (each 5 s long, like the parameter TRC_STOP_T15_TO) traces are recorded indefinitely. Please, see figure "Issue_3".
Could you please help me? In attachment, you can find the config.txt file.
Thank you,
Alessandro
Issue_3
Issue_3
Issue_2
Issue_2
Issue_1
Issue_1
config - 24-11-28.txt
config file
(11.05 KiB) Downloaded 14420 times
alessandrop
Re: Issues with trace recording
Post by alessandrop » Fri 29. Nov 2024, 11:47
Unfortunately, this morning I found a problem in the setup that I used yesterday for my tests. Basically, when yesterday I assumed that the CAN traffic was OFF, actually it was still ON for 10-15 s. This morning I solved this problem, so now I'm no more able to replicate the phenomenon reported in figure "Issue_2". So, please, excuse me and ignore that issue.
On the other hand, I tried to replicate the phenomena described by figures "Issue_1" and "Issue_3" and I still have both problems.
As a matter of clarification for "Issue_1", I produced two more screenshots describing whant I meant when I wrote Sometimes, I'm able to obtain the expected behaviour retriggering the Wake-Up signal (ON-->OFF-->ON), but the new file doesn't have an incremented index: please, see figures "Issue_1_addendum_1" and "Issue_1_addendum_2".
Basically, sometimes when the memory card is full, I'm able to obtain the circular-append option by retriggering the Wake-Up signal (ON --> OFF for at least 5 s --> ON), so that the oldest file is deleted as expected, but the new file doesn't have an incremented index, its index starts again with 1.
In principle, this is not a big deal. The real problem is that this behaviour doesnt' happen all the times. Sometimes the device behaves this way, sometimes behaves like reported in figure "Issue_1" in my original post of yesterday afternoon.
Could you please give me an help?
Thank you,
Alessandro
Three traces are recorded, then the memory card is full.
After retriggering the Wake-Up signal, the oldest file is replaced by a new one.
Post by M.Heidemann » Mon 2. Dec 2024, 11:33
Can you tell us the used Firmware?
Did you make sure that you also use a matching config file?
BR
alessandrop
Post by alessandrop » Thu 5. Dec 2024, 16:51
Hello Marvin,
Thank you for your reply.
The installed FW version is the 1.2.0.13, please see the attached picture.
In the meantime, I made other tests and I found six different cases that belong to three common scenarios: A, B, and C. Such scenarios are summarised in the attached pictures and in the following list:
  • A: CAN traffic is OFF, device is powered ON, CAN traffic is still OFF, after at least 5 s the Wake-up signal goes ON, CAN traffic goes ON, memory card becomes full, Wake-up signal goes OFF for at least 5 s, Wake-up signal goes ON --> The feature circular-append doesn't work, several 0 kB traces are stored.
  • B: CAN traffic is OFF, device is powered ON, CAN traffic goes ON for more than 5 s, Wake-up signal goes ON, memory card becomes full, Wake-up signal goes OFF for at least 5 s, Wake-up signal goes ON --> A short trace 5 s long is stored at the beginning. The feature circular-append doesn't work, several 0 kB traces are stored.
  • B: CAN traffic is ON, device is powered ON, CAN traffic is still ON for more than 5 s, Wake-up signal goes ON, memory card becomes full, Wake-up signal goes OFF for at least 5 s, Wake-up signal goes ON --> A short trace 5 s long is stored at the beginning. The feature circular-append doesn't work, several 0 kB traces are stored.
  • C: CAN traffic is OFF, device is powered ON, Wake-up signal goes ON in less than 5 s, CAN traffic goes ON, memory card becomes full, Wake-up signal goes OFF for at least 5 s, Wake-up signal goes ON --> The feature circular-append works, but the new file doesn't have an incremented index, its index starts again with 1.
  • C: CAN traffic is OFF, device is powered ON, CAN traffic goes ON for less than 5 s, Wake-up signal goes ON, memory card becomes full, Wake-up signal goes OFF for at least 5 s, Wake-up signal goes ON --> The feature circular-append works, but the new file doesn't have an incremented index, its index starts again with 1.
  • C: CAN traffic is ON, device is powered ON, CAN traffic is still ON for less than 5 s, Wake-up signal goes ON, memory card becomes full, Wake-up signal goes OFF for at least 5 s, Wake-up signal goes ON --> The feature circular-append works, but the new file doesn't have an incremented index, its index starts again with 1.
Does the device is intended to work this way?
Thank you,
Alessandro
Post by M.Heidemann » Fri 6. Dec 2024, 09:02
Let me ask you again, can you confirm, that the config file MATCHES the current Firmware?
Also, can you send us your config?
We'll need a reference to get any idea whats going on here.
BR
alessandrop
Post by alessandrop » Fri 6. Dec 2024, 11:34
I already attached the config file in my first post, anyway you can find it also in this reply post.
Regarding the "matching config file" question: since I simply modified the original config file that was provided together with the data logger, I suppose that it should match the installed FW version.
Best,
Alessandro
(11.05 KiB) Downloaded 14250 times
alessandrop
Post by alessandrop » Fri 20. Dec 2024, 10:00
Dear PEAK-Support Team,
Did you have time to investigate the issues that I reported in my previous posts?
Thank you,
Alessandro
Post by M.Heidemann » Fri 20. Dec 2024, 12:23
Hello Alessandro,
Issues as involved as this might be a better fit for an email request, i have to admit i lost track due to a high volume of support requests, i'm terribly sorry.
Is this behavior replicable with both writing to EMMC as well as SD-Card?
Also, just as a suspicion on my side:
Can you re-download the DevPack and flash the latest firmware again and use the latest config file as well?
https://www.peak-system.com/quick/DLP-DevPack
The behavior is quite strange, i almost suspect something in regards of the firmware got corrupted,
let's see if we can replicate this with a fresh install.
And once again sorry for the long delay!
BR
alessandrop
Post by alessandrop » Tue 24. Dec 2024, 15:05
Hello Marvin,
Thank you for your reply. I re-download the DevPack using your link and flashed the device first with rprofd_bl_upgrade_2_1_0.bin bootloader version and then with the latest firmware version Logging-Firmware_1.2.1.15.bin.
I performed the tests described in my post of Thursday, 5th December, using the latest config file available, and I can replicate Scenarios A and B. Unfortunately, I can no longer replicate Scenario C, which was not optimal but was at least a working condition.
Do you have any idea to solve such an issue?
Thank you,
Alessandro
Post by M.Heidemann » Thu 2. Jan 2025, 12:52
so we don't lose track, what's the current behavior you do see?
Can you outline which behavior specifically is reproducable (you have multile items under A, e.g)
