Python fails to “from pcan.PCANBasic import *”
jjollota
Post by jjollota » Tue 21. Jan 2025, 16:46
I have seen a number of posts about this topic, and I believe I have tried everything that was suggested, but I cannot get this pcan.PCANBasic import to work.
I have tried:
• Installed latest PEAK-System_Driver-Setup
• Verified 64bit DLL in System32 and 32bit in SysWow64
• Tried copying each PCANBasic.DLL to local directory.
Should there be an explicit PATH statement with “pcan” in it?
Any other steps to isolate the problem?
Jim
Re: Python fails to “from pcan.PCANBasic import *”
Post by M.Heidemann » Wed 22. Jan 2025, 08:56
Is the header file "PcanBasic.py" present?
BR
jjollota
Post by jjollota » Thu 23. Jan 2025, 19:00
Yes, I have everything in one directory, including the PCANBasic.py.
Jim
Post by M.Heidemann » Fri 24. Jan 2025, 11:35
Can you share part of your code, especially the imports?
jjollota
Post by jjollota » Fri 24. Jan 2025, 17:38
Yes, it is the start of the python file:
try:
    from tqdm import tqdm
    import ctypes
except ImportError:
    print('[ERROR] Dependant modules not available of PCANBasic.')
    print('')
    sys.exit()
And it fails on the pcan.PCANBasic import line
Reason: Code formatted for better reading
Post by K.Wagner » Mon 27. Jan 2025, 11:35
if you have the drivers and PCAN-Basic installed (PEAK-Drivers Setup), and also Python, then you should be able to load and use the library. It could be a problem with environment configuration in Pyhton itself. Which Python version are you using? which OS are you using?
In normal cases, you should be able:
  • to compile and launch the Pyhton samples contained in the PCAN-Basic package (console and GUI. The last one uses tkinter).
  • to load the PCANBasic.py module with Python IDLE and run it. Over the console then directly call the API functions.
Please try downloading the PCAN-Basic package (if you do not have it), and give the sample projects a try.
jjollota
Post by jjollota » Mon 27. Jan 2025, 19:36
Keneth,
Thank you for your help on this. I am not a Python-guy, but your examples were key. Your examples imported the library via "from PCANBasic import *", but the example code I got from the microprocessor company was "from pcan.PCANBasic import *". I don't know the ramifications of the difference, but your line does not exception.
Jim
Post by K.Wagner » Tue 28. Jan 2025, 10:58
OK. I missed the incorrect import in your code.
Thanks for the feedback.
Closed.
