Peak chardev driver on Linux stops reading abruptly
USB to CAN Interface
eoztosun
Post by eoztosun » Mon 17. Mar 2025, 12:15
I have an application based on PCAN-Basic API. The application runs without any problems on Windows 10 and Windows 11. I'm trying to port it to debian Linux.
I installed the chardev peak driver, following the instructions in the README within the package. When I try to run RX examples, they stop after a while. My Application's RX also stops after a while.
ls /dev | grep pcan
gives
  • pcan32
    pcan-usb
    pcanusb32
sudo dmesg
gives
PCAN-USB CAN1: controller internal Rx queue overflow: possible loss of msgs(s)
I'm receiving a single message with 10ms period from a single node. How come RX queue can be full. Documentation suggests that the default RX buffer is 2000 and it can be configured. I configured it to 30000 to see if it solves but didn't work.
Re: Peak chardev driver on Linux stops reading abruptly
Post by M.Maidhof » Mon 17. Mar 2025, 14:11
please post the output of cat /proc/pcan before and after the reading stops. Can you please show a photo of the used PCAN hardware, to see which version you are using?
eoztosun
Post by eoztosun » Tue 18. Mar 2025, 07:37
Here is the PCAN-View description of the device at hand
Here is
cat /proc/pcan
output before any read operation, after powering the Debian/Linux (intel x86) computer with aforementioned PCAN-USB attached.
Here is
cat /proc/pcan
output after read operation.
Here is the
sudo dmesg
output after the reading stops.
I tried on a virtual machine on my Windows computer, same result. Examples on peak driver and PCAN-Basic driver and my own application, they all have the same issue. Reading stops after a while. When I re-run, it reads a while and then stops again.
Post by M.Maidhof » Wed 19. Mar 2025, 08:23
please send a photo of the adapter showing the serial number to our support email address, to see which hardware you are using.
eoztosun
Post by eoztosun » Thu 20. Mar 2025, 07:55
The problem seems to be solved but I have no idea how. I am not able to reproduce it. And I don't think I have made any configuration changes.
Thank you for your support
Edit: Please keep the post for a while in case if it occurs again
