BODAS Software won't work with driver 5.x
Post by M.Maidhof » Wed 25. Feb 2026, 08:54
we received some support requests regarding an issue that the Bosch Rexroth BODAS software won't work on systems on which the latest PEAK-Driver 5.x are installed.
There is an error dialog displayed which tells you "Driver version not supported (needs 3.x):
In that case, please uninstall the driver 5.x in the device manager CAN-Hardware/PCAN-USB (right mouse click uninstall) and click on the option to remove the driver files, when you will be asked for. Do this several times until no driver is left for PCAN-USB (unplug and replug the PCAN-USB from the USB port). Restart Windows once and install the driver setup 4.6.4 from the following link:
https://www.peak-system.com/quick/DrvSetup_4x
This should fix the issue with the BODAS Software tool, until there will be an update available which also accept newer driver versions from PEAK.
