Hi ,
I want to add all my tx message from transmit list document (.xmt) to "Receive/Transmit" window.
by using code(Macro file)
I'm able to open my transmit list document ,
"Set doc = Documents.Open("$(CurDir)\Mytransmit.xmt",,True) "
I saw the document and send all messages. but I can't see it from "Receive/Transmit" window.
and now I want to pause all the message
"Connections.TransmitMessages.PauseAll"
this code only work to pause all message in "Receive/Transmit" window. I want to pause all my message in "Mytransmit.xmt".
Do you know how to put the message from Mytransmit.xmt to "Receive/Transmit" window?
Thanks before.
Tx Message From Transmit List Doc(.xmt) to Receive/transm
Re: Tx Message From Transmit List Doc(.xmt) to Receive/tra
Transmit List documents are always opened in a separate document window. The messages in the Receive/Transmit window are stored in the project file.
There is no easy way to put all messages from the transmit list document into the Receive Transmit window. In the user interface you could use the File->Import command, but this function cannot be automated through a macro without user interaction.
But you can control the messages in the transmit list window:
The Connections.TransmitMessages collection only represents the transmit list in the Receive/Transmit window. But each open transmit list window has its own TransmitMessages collection, which you can control in the same way.
doc.ActiveWindow.Object.Messages.PauseAll
Hi ,
Thank you for your reply ,
I tried this example from help file and give warning ( how to fix this warning ?)
Sub KindExample()
' Open a text document before executing this example
Dim objDoc
Set objDoc = ActiveDocument
MsgBox "Kind of the active document: " & objDoc.Kind
End Sub
Your code
I tried this code, and this code only for one spesific file,
and I want to Pause all my transmit list file which are opened or activate in window
so I do
dim win
For Each win In Windows
If win = Windows(peDocumentKindTransmit) Then
win.Object.Messages.PauseAll
end if
Next
it's work,
but it's only work to pause only one file not all my all active transmit file .
do you know how to pause all active transmit file at window?
Thank you
Sub KindExample()
Dim objDoc
End Sub
Your code
so I do
dim win
end if
Next
it's work,
Thank you
try this code:
try this code:
Dim win
If win.Kind = peDocumentKindTransmit Then
End If
Next
