Symbols not appearing when selected in Add Filter window
Posted: Fri 5. Apr 2013, 18:30
I want to add filters that use the active symbols and they aren't appearing as a selection when I choose Adjust to Symbols. So I marked a symbol for trace and it isn't appearing in Adjust to marked Symbols. What setting am I missing to get the symbols to appear?
I found that marked traces are working if I select this. I was expecting to see something in the details section to be able to select which traces to use. I have not tried the Adjust to Symbols. I expect that all symbols in my symbol file will most likely be filtered. I was expecting symbols to be in the Details section so I could select which ones.
No answer needed for this post.
