My setup is as followed:
PCAN-GPRS Link, using CAN2 port on supplied cableset
PCAN-USB
Since both have male connectors I made a female-female cable myself to put it in between. Since I keep getting stuff errors (not receiving data in both ways) I'm asuming termination resistors could be the issue. I can't find anywhere whether the PCAN-GPRS Link cableset is terminated (at either end). If this is not the case, do I only have to terminate my self-made cable? (I'm new to working with CAN and the exact location of termination resitors in my setup isn't clear to me)
Info (as asked from someone else in a different topic):
- PCAN_USB.sys -> 3.5.4.9547
- Baudrate 500k (which leads me to another problem, PCAN-GPRS Link header file defines '3C' as baudrate. On PCAN Nets config that results in 444kbit/s 77% SP, does this relate to clock speed?)
- Termination: none in my cable, can't find anything about the supplied PCAN-GPRS Link cable so don't know
- PCAN-USB light is flashing rapidly while transmitting dummy data, slowly when on hold
I hope this provides enough info my problem. Thanks in advance!
PCAN-USB & PCAN-GPRS Link
Re: PCAN-USB & PCAN-GPRS Link
Hello expor,
all products from us are not terminated. So you have to terminate your cable or use a PCAN-Term (product page) on both ends. Without termination it is not possible to communicate over CAN.
Best regards
Fabian Hessemer
Development
Best regards
Fabian Hessemer
Development
Thanks for the quick reply.
Does this mean I cannot use the automotive connector cable supplied with the PCAN-GPRS Link? In other words, is it necessary to terminate the cable at the automotive connector, or is it sufficient to terminate my self-made cable on both it's connectors. (one end directly connected to PCAN-USB, the other end connected to the supplied cable set)
it works when you terminate your cable. Just plug in a 120 Ohm resistor at both ends between CAN_H and CAN_L.
Best regards
Fabian Hessemer
Development
Best regards
Fabian Hessemer
Development
