CoDeSys&Wireless Gateway
I wanna use the Software CoDeSys with the Wireless Gateway to get ride of the PEAK USB Dongel. I can trace the CAN traffic with PCAN Explorer 5 using the Wireless Gateway.
But if i try to send Software updates out of CoDeSys, i get a communication Error. I think i use the wrong communication Parameter.
The attached images shows the communication box in CodeSys. If i use the USB Dongel, the driver is set to PEAK_USB. I tried PEAK_LAN, PEAK_VIRTUAL but it dosent work, i still get a communication error.
Right now i use TCP as transmission protocol on the Gateway.
Anyone got experience using CoDeSys together with the Peak Gateways?
- 2.png (12.85 KiB) Viewed 18581 times
Re: CoDeSys&Wireless Gateway
Please contact 3S-Software . If they include as optional Device Type the Virtual CAN Interface it should work. It is exact the same API as used for PCAN-USB, PCAN-PCIe etc. Only the Device Handle is new (new Device Driver)
But this must be done inside CodeSys. We have no access to change / add any Device.
Short Update, i called the Support again, they are working on it.
Thanks for the feedback - we know - we have send them some Ethernet and Wireless Gateways to test their development with real Hardware.
I've just talked to the CoDeSys Support.
Bad News, they wont implement the Wireless Gateway into CoDeSys Version 2.3, it should/can work with Version 3, no real answer there.
Version 3 of CoDeSys dosent work with our Controllers. (Hydac TTC60)
Now we are at the Point were we could switch to IXXAT Hardware + IXXAT CAN Explorer, fully supported by CoDeSys or try to find a solution.
Is there any way to send the the CoDeSys Project/Boot Project form the PC to the Wireless Gateway -> Controller?
CoDeSys told me, they not responsible after the Boot Project is build.
Sorry, we could not help you in this matter. Good luck with the new Interface - hopefully you get the support you need..Is there any way to send the the CoDeSys Project/Boot Project form the PC to the Wireless Gateway -> Controller?
Hello!
Same Problem here, just for the PCAN-Ethernet Gateway DR (IPEH 004010).
I am connected and recieve live-data from an IFM at my pc via Ethernet, visualized at the PCAN-View.
But i am not able to connect to the IFM via CodeSys. I use CodeSys 2.3 and a IFM CR0401.
There is integration for the wireless gateway, but what about the wired gateway?
Is there a solution by now? Some special CAN card driver for connecting via Ethernet?
cheerz
cheerz
- code.PNG (19.8 KiB) Viewed 14598 times
Please contact 3S - as far as we know they support the Gateways in 3-x up. See here
It makes no different if you use a Wireless CAN-Gateway (WLAN) or the Ethernet-CAN Gateway (LAN) It both ends up in a Ethernet Socket on the PC / Driver.
I have a problem that i can not find the Controller in Codsys 3.5 SP14 when i use Peak wireless Gateway. instead of the normal Peak dongle the Peak Wireless Gateway is used to connect the Controller to Codesys. but i can not find the controller in Device search in codesys
Please contact Codesys - as far as we know you need to use the latest Version (but as i wrote - please contact the software manufacturer )
