Issues with trace recording
Programmable 6-channel router and data logger for CAN and CAN FD with I/O and optional Ethernet interface
alessandrop
Re: Issues with trace recording
Post by alessandrop » Tue 7. Jan 2025, 09:40
Hello Marvin,
Actually, since there were so many problems with the provided firmware, I decided to implement my own custom firmware. Starting from example 21_RTOS_FILESYSTEM and others, I'm now able to:
  • record traces on file of customisable size
  • use a timeout based on CAN traffic and Wake-Up signal detection for saving the file
  • check if the disk is full, then delete the oldest file and a create a new one
The only thing that I was not able to implement so far is the customisation of the baud rate for the different CAN channels without flashing every time a new firmware version.
I basically would like to replicate the feature of the provided firmware, so that I can assign the baud rate for every channel via file.
Since I know that modifying the following variable in can_user.c
static const CANTiming_t  Timing_CANx[6] = {
_40M_250K_80____2M_80_ISO,	  // CAN1
_40M_250K_80____2M_80_ISO,	  // CAN2
_40M_500K_80____4M_80_ISO,	  // CAN3
_40M_250K_80____2M_80_ISO,	  // CAN4
_40M_250K_80____2M_80_ISO,	  // CAN5
_40M_250K_80____2M_80_ISO	  // CAN6
it is possible to change the speed for every channel, I looked for every instances of it and I tried to modify CAN_UserRead, CANQUEUE_TimerCB, CANQUEUE_Startup, and CAN_UserInit functions in order to let them accept a CANTiming_t variable as input from the main function.
Unfortunately, I failed in this. Even if the code compilation goes well, with my implementation no more traces are recorded. Could you please provide me a help? Maybe a sample code of this part already implemented?
Thank you,
Alessandro
Post by M.Heidemann » Tue 7. Jan 2025, 10:09
Hello Allesandro,
These bitrate-constants are defined in can_user.h ("Inc" folder), if you want to use a different bitrate-config or define your own,
please modify/check this file.
BR
alessandrop
Post by alessandrop » Tue 7. Jan 2025, 10:41
As above described, I already found that modifying that file it is possible to use different bitrate. But, I would like to do it programmatically, at runtime.
And given that in the provided firmware this feature is already implemented, I was wondering if you can provide an already working sample code for that part.
Post by M.Heidemann » Tue 7. Jan 2025, 10:50
have a look at the corresponding can_user.c,
this is the init-sequence for the channels.
Use CAN_UnInitialize to bring a channel down again and bring it back up using
CAN_Initialize ( hBus, &Timing_CANx[hBus]);
Make sure to use your intended bitrate for reinitialization.
This should enable your to change birate during runtime.
BR
alessandrop
Post by alessandrop » Thu 9. Jan 2025, 08:31
Thank you for the support, using both CAN_UnInitialize and CAN_Initialize worked.
Locked
