ECUs and the CCP Interface
Will your CCP interface (PCCP.dll) communicate successfully with any ECU loaded with CCP v2.1 regardless of the manufacturer of the ECU. Thanks.
Re: ECUs and the CCP Interface
Yes. CCP is a standardized protocol. Our CCP API was developed using the CCP specifications 2.1 from ASAM, which means that any ECU supporting CCP v. 2.1, regardless of it manufacturer, should be able to communicate with applications using a CAN Hardware from PEAK and the PCCP.dll.
...and remember... The CCP Api and the still in development XCP Api, are offered for free.
Thanks for your reply. Your support software for your products is superior.
