with UDSApi.Write how can I send an uudt 11 or 29 bit message id?
ie 0x100 in 11 bit format id and 0x100 in 29 bit format
cappo
How to send 11 and 29 bit identifier
Re: How to send 11 and 29 bit identifier
Dear cappo,
You will find a complete UUDT example in the documentation of the PCAN - UDS API :
- §4.3.3 "UUDT Read / Write example" p.343.
void sample_rw_uudt(TPUDSCANHandle channelTx, TPUDSCANHandle channelRx) {
TPUDSStatus status;
int iBuffer;
TPUDSMsg Message;
int count;
// Initializes UDS Communication for the transmitting channel
status = UDS_Initialize(channelTx, PUDS_BAUD_500K, 0, 0, 0);
printf("Initialize UDS: %i\n", (int)status);
// Initializes UDS Communication for the receiving channel
status = UDS_Initialize(channelRx, PUDS_BAUD_500K, 0, 0, 0);
printf("Initialize ChannelRx: %i\n", (int)status);
// Define "channelTx" Address as ECU #9
iBuffer = 0xF9;
status = UDS_SetValue(channelTx, PUDS_PARAM_SERVER_ADDRESS, &iBuffer, 1);
printf(" Set ServerAddress: %i (0x%02x)\n", (int)status, iBuffer);
// Define "channelRx" Address as External equipement
iBuffer = 0xF1;
status = UDS_SetValue(channelRx, PUDS_PARAM_SERVER_ADDRESS, &iBuffer, 1);
// Prepare mapping configuration:
// UUDT physical response from ECU_#9 to External_Equipment : ID=0x526
Message.NETADDRINFO.SA = 0xF9;
Message.NETADDRINFO.TA = 0xF1;
Message.NETADDRINFO.TA_TYPE = PUDS_ADDRESSING_PHYSICAL;
Message.NETADDRINFO.RA = 0x00;
Message.NETADDRINFO.PROTOCOL = PUDS_PROTOCOL_NONE;
Message.LEN = 4;
// data[0..3] holds CAN ID
Message.DATA.RAW[0] = 0x00;
Message.DATA.RAW[1] = 0x00;
Message.DATA.RAW[2] = 0x05;
Message.DATA.RAW[3] = 0x26;
// Add "channelTx" mapping (in order to send message)
// for UUDT physical response from ECU_#9 to External_Equipment : ID=0x526
status = UDS_SetValue(channelTx, PUDS_PARAM_MAPPING_ADD, &Message, sizeof(Message));
printf(" Add UUDT mapping: 0x%04x\n", status);
// Add "channelRx" mapping (in order to receive message)
status = UDS_SetValue(channelRx, PUDS_PARAM_MAPPING_ADD, &Message, sizeof(Message));
printf(" Add ChannelRx UUDT mapping: 0x%04x\n", status);
// Write a message from "channelTx" to "channelRx"
Message.LEN = 6;
Message.DATA.RAW[4] = 0xCA;
Message.DATA.RAW[5] = 0xB1;
status = UDS_Write(channelTx, &Message);
printf(" UDS_Write UUDT: 0x%04x\n", status);
// Read message on channel Rx
printf(" Reading message on ChannelRx...\n");
memset(&Message, 0, sizeof(Message));
count = 0;
do {
count++;
Sleep(100);
status = UDS_Read(channelRx, &Message);
} while (status == PUDS_ERROR_NO_MESSAGE && count < 10);
if (status == PUDS_ERROR_NO_MESSAGE)
printf("Failed to read message on Channel RX !");
else {
// Received message will hold Network Address Information
// as defined by the mapping.
// The CAN ID information is removed from the DATA.RAW field.
displayMessage(NULL, &Message);
UDS_Uninitialize(channelTx);
I wrote here after I read that example...
So take the example code
0x256 can be an 11 or 29 bit identifier..... and how can I set this parameter?
To be claer the same thing that in isotp write is PCANTP_ID_CAN_29BIT or PCANTP_ID_CAN_11BIT.
cappo
Message.LEN = 4;
cappo
You are right. Currently the PCAN-UDS UUDT mechanism does not handle 29 bit flag.
Nevertheless you can write your UUDT message with PCAN-ISO-TP API using the CAN handle initialized by PCAN-UDS as such:
The UDS_Read function will return a UDS message with CAN ID 0x526 in the DATA field, but you will not be able to tell if it is a 11bit or 29 bit CAN ID.
void sample_rw_uudt_29b(TPUDSCANHandle channelTx, TPUDSCANHandle channelRx) {
// Write a 11 bit message from "channelTx" to "channelRx" with PCAN-UDS
//Message.LEN = 6;
//Message.DATA.RAW[4] = 0xCA;
//Message.DATA.RAW[5] = 0xB1;
//status = UDS_Write(channelTx, &Message);
// Write a 29 bit message from "channelTx" to "channelRx" with PCAN-ISO-TP
TPCANTPMsg tpmsg = {};
tpmsg.FORMAT = PCANTP_FORMAT_NONE;
tpmsg.MSGTYPE = PCANTP_MESSAGE_UNKNOWN;
tpmsg.IDTYPE = PCANTP_ID_CAN_29BIT;
tpmsg.TA_TYPE = PCANTP_ADDRESSING_UNKNOWN;
tpmsg.LEN = 6;
tpmsg.DATA[0] = 0x00;
tpmsg.DATA[1] = 0x00;
tpmsg.DATA[2] = 0x05;
tpmsg.DATA[3] = 0x26;
tpmsg.DATA[4] = 0xCA;
tpmsg.DATA[5] = 0xB1;
status = CANTP_Write(channelTx, &tpmsg);
Okay, thanks!
cappo
cappo
