Latency on PCAN-Router Pro
4-Channel CAN Router with Data Logger
Cris417
Post by Cris417 » Fri 23. Aug 2019, 10:42
What is the latency between End of Frame at the input port, and Start of Frame at the output port ?
In best case, low traffic and no conflicts.
Just forwarding the frame without any change.
I am working with 500kbps CAN speed.
Thanks.
Re: Latency on PCAN-Router Pro
Post by PEAK-Support » Fri 23. Aug 2019, 11:23
this is depending of what exact is configred, but if you only use simple 1:1 routing we talk about milli seconds.
