Wrong PIDs in ReadDataByPeriodicIdentifier
ValeV
Post by ValeV » Wed 28. Aug 2019, 14:50
I call service ReadDataByPeriodicIdentifier at medium rate, wanting to read 0xF200 and 0xF204.
My code:
string TC_UDS_266()
    string s;
    TPUDSStatus r;
    unique_ptr<PUDSClass> pcan(new PUDSClass());
    if (pcan->openDevice(PUDS_USBBUS1, PUDS_BAUD_250K) != PUDS_ERROR_OK)
        cout << "UDS-266: failed to initialize" << endl;
        return "UDS-266: FAILED";
    cout << "initialized" << endl;
    TPUDSMsg requestConfirmation;
    TPUDSMsg response;
    memset(&requestConfirmation, 0, sizeof(TPUDSMsg));
    memset(&response, 0, sizeof(TPUDSMsg));
    WORD bufferLength = 2;
    BYTE buffer[bufferLength] = {};
    buffer[0] = '00';
    buffer[1] = '04';
    r = pcan->SvcReadDataByPeriodicIdentifier(&pcan->request, 0x01, buffer, bufferLength);
    if (r == PUDS_ERROR_OK)
        r = pcan->WaitForService(&response, &requestConfirmation);
        cout << "Response was received" << endl;
        //cout << "SID: " << response.DATA.POSITIVE.SI << endl;
        s = "UDS-266: PASSED";
    else
        cout << "An error occured" << endl;
        s = "UDS-266: FAILED";
    return s;
Problem is, when I'm watching data on other device, i see these 2 messages:
Send: [04 2A 01 30 34]
Received: [03 7F 2A 7F]
The response is ok, since this service is no allowed in default session, but I can't understand why it sends "... 30 34]" and not "...00 04]". Even if I set buffer (PIDs) to ["A0", "B4"], it still sends "30" and "34". :?
F.Vergnaud
Re: Wrong PIDs in ReadDataByPeriodicIdentifier
Post by F.Vergnaud » Wed 28. Aug 2019, 15:11
Dear Valev,
The following code is incorrect, as you are confusing an integer hex value with a char value (char '04' is 0x34 in ascii):
    buffer[0] = '00';
    buffer[1] = '04';
Also your code should not compile without a const value in front of "WORD bufferLength = 2;"
Here is the corrected version:
    const WORD bufferLength = 2;
    buffer[0] = 0x00;
    buffer[1] = 0x04;
Fabrice
ValeV
Post by ValeV » Wed 28. Aug 2019, 15:48
Thank you, easy fix for more experienced programmers. :)
I have no problems even if I don't have "const" there. In your API user manual, in example, there also is no "const" there. Are you sure it's needed?
F.Vergnaud
Post by F.Vergnaud » Wed 28. Aug 2019, 15:57
It may depends on your compiler but on VS2019 it doesn't.
Fabrice
ValeV
Post by ValeV » Thu 29. Aug 2019, 08:24
I see, I have GCC, no problems here. Will keep in might if anything goes wrong. Thank you again for the help.
