Drivers compilation failure in RedHat7
mcabon
Post by mcabon » Mon 9. Sep 2019, 15:49
Hey everyone.
In first time, thanks for your help.
I have a PCAN-USB that I would like to communicate with a VM in Red Hat7.
I downloaded the drivers: peak-linux-driver-8.9.0.
I did this:
- make clean:
[root@localhost driver]# make clean
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd  pcan.mod.c Module.symvers modules.order .cache.mk
-make:
*** Host machine kernel version=3.10.0-862.el7.x86_64
*** Driver kernel version=3.10.0-862.el7.x86_64 (3.10.0)
*** Path to kernel sources=/lib/modules/3.10.0-862.el7.x86_64/build
*** use KBUILD=yes
*** gcc version=4.8.5
make -C /lib/modules/3.10.0-862.el7.x86_64/build  EXTRA_CFLAGS="-I/root/Desktop/peak-linux-driver-8.9.0/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT " V=0 modules SUBDIRS=/root/Desktop/peak-linux-driver-8.9.0/driver
make[1] : on entre dans le répertoire « /usr/src/kernels/3.10.0-862.el7.x86_64 »
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_main.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_fops.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_fifo.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_filter.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_parse.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_sja1000.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_common.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_timing.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcanfd_core.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcanfd_ucan.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_usb_core.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_usb.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_usbpro.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcanfd_usb.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_pci.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcanfd_pci.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_pciec.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_isa.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_dongle.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_pccard_core.o
  CC [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/src/pcan_pccard.o
  LD [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/pcan.o
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: "pcmcia_dev_present" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
WARNING: "pcmcia_enable_device" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
WARNING: "pcmcia_register_driver" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
WARNING: "pcmcia_request_io" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
WARNING: "pcmcia_loop_config" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
WARNING: "pcmcia_unregister_driver" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
WARNING: "pcmcia_disable_device" [/root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko] undefined!
  CC      /root/Desktop/peak-linux-driver-8.9.0/driver/pcan.mod.o
  LD [M]  /root/Desktop/peak-linux-driver-8.9.0/driver/pcan.ko
make[1] : on quitte le répertoire « /usr/src/kernels/3.10.0-862.el7.x86_64 »
- make install:
[root@localhost driver]# make install
Info: /lib/modules/3.10.0-862.el7.x86_64/misc exists.
depmod: ERROR: Could not create index 'modules.dep'. Output is truncated: No space left on device
make: *** [install_udev] Erreur 1
I don't understand why for the error ...
but for - modprobe pcan :
[root@localhost driver]# modprobe pcan
and if i check with cat /proc/pcan ...
[root@localhost driver]# cat /proc/pcan
cat: /proc/pcan: Aucun fichier ou dossier de ce type
so ... someone could you help me ?
thanks so much !
S.Grosjean
Re: Drivers compilation failure in RedHat7
Post by S.Grosjean » Mon 9. Sep 2019, 16:38
I think it can't be clearer!
The installation process has failed because because your hard disk is running out of space. You should exit your VM then enlarge the size of the virtual disk.
— Stéphane
mcabon
Post by mcabon » Mon 9. Sep 2019, 17:10
hi,
thanks you for your answer ! :)
so I expanded the size of my VM.
but I still have a mistake. I make the make clean/ make install ok but the pcan modprob makes me a mistake...
-make
*** use KBUILD=yes
  MODPOST 1 modules
-> I have a question: why we have a WARNING with pcmcia ?
-make install
-modprobe pcan
modprobe: ERROR: could not insert 'pcan': Unknown symbol in module, or unknown parameter (see dmesg)
modprobe: ERROR: Error running install command for pcan
- cat /etc/modprobe.d/pcan.conf
[root@localhost driver]# cat /etc/modprobe.d/pcan.conf
options pcan type=isa,sa irq=10,5 io=0x300, 0x320
install pcan modprobe --ignore-install pcan
thanks for your helps
Post by M.Maidhof » Mon 9. Sep 2019, 17:28
please build the driver without PCMCIA support:
make PCC=NO
mcabon
Post by mcabon » Mon 9. Sep 2019, 17:36
i build with
make PCC=NO
[root@localhost driver]# make PCC=NO
*** use KBUILD=yes
make -C /lib/modules/3.10.0-862.el7.x86_64/build  EXTRA_CFLAGS="-I/root/Desktop/peak-linux-driver-8.9.0/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DNO -DNO_NETDEV_SUPPORT -DNO_RT " V=0 modules SUBDIRS=/root/Desktop/peak-linux-driver-8.9.0/driver
  MODPOST 1 modules
-make install
-modprobe pcan
modprobe: ERROR: could not insert 'pcan': Invalid argument
i don't understand why modprobe pcan they are error :/
thanks, Mylene
mcabon
Post by mcabon » Tue 10. Sep 2019, 09:00
hi everyone,
i tried this :
- modinfo pcan.ko | grep -e "^depends:"
[root@localhost driver]# modinfo pcan.ko | grep -e "^depends:"
depends:        i2c-core,parport,i2c-algo-bit
[root@localhost driver]# sudo modprobe i2c-core parport i2c-algo-bit
[root@localhost driver]# sudo insmod pcan.ko
[root@localhost driver]# sudo modprobe pcan
and when i test :
- cat /proc/pcan
*------------- Release_20190802_n (8.9.0) Sep 10 2019 08:49:30 --------------
*---------------- [mod] [isa] [pci] [pec] [dng] [par] [usb] -----------------
*--------------------- 1 interfaces @ major 242 found -----------------------
32    usb   -NA- ffffffff 000 0x001c 00000000 00000000 00000000 00000000 0x0000
I thinks it's good :)
S.Grosjean
Post by S.Grosjean » Tue 10. Sep 2019, 10:06
FYI, you don't have to insmod then modprobe.
This kind of error comes from the fact that you don't have the root rights to run the modprobe command. Therefore, to use the modprobe commmand (as well as the insmod one), you have to use the "sudo" command.
Thus,
is enough.
— Stéphane
mcabon
Post by mcabon » Tue 10. Sep 2019, 10:14
hooo, okay :)
Thanks for your explication ! :)
