busoff
Universal Programmable Converter for CAN FD and CAN
brutkows
busoff
Post by brutkows » Thu 31. Oct 2019, 14:05
When I briefly short the CAN1 bus of a PCAN Router-FD it stops receiving or sending CAN on that bus until the power is cycled.
I can see with CANalyzer that the CAN1 bus is active, but the CAN1 Rx light does not flash.
I can send a message on CAN2 and get the CAN2 Rx light to flash but the message does not get gatewayed to CAN1.
Is there a way to detect this busoff condition and fix it on-the-fly?
Brian
G.Bohlen
Hardware Development
Re: busoff
Post by G.Bohlen » Fri 1. Nov 2019, 08:51
Hello Brian,
please have a look at the examples, e.g. "1_ROUTING".
In the file can_user.c you find:
CANResult_t  CAN_UserRead ( CANHandle_t  hBus, void  *buff)
	CANResult_t  ret;
	CANBuffer_t  *rx_buff;
	ret = CAN_ERR_RX_EMPTY;
	rx_buff = buff;
	if ( CAN_Read ( hBus, rx_buff) == CAN_ERR_OK)
		// buffer read from CANx. Check type of buffer.
		switch ( rx_buff->bufftype)
			case CAN_BUFFER_STATUS:
				// the buffer is a status notification from the CAN controller.
				if ( rx_buff->status.bus_status)
					// CAN controller not involved into bus activities
					// uninitialize (this includes a TX-path flush)
					CAN_UnInitialize ( hBus);
					// initialize CAN controller
					CAN_Initialize ( hBus, &Timing_CANx[hBus]);
				break;
			case CAN_BUFFER_RX_MSG:
				// the buffer is a receive message. Forward to application.
				ret = CAN_ERR_OK;
				break;
			case CAN_BUFFER_CRITICAL:
				// receive queue level was critical. Data might be lost.
				break;
	return ret;
If CAN_Read() returns a buffer-type "CAN_BUFFER_STATUS" then this is a status-message, not a data-message.
rx_buff->status.bus_status==1 means: bus off .
This code does an uninitialize followed by an initialize of the CAN-Controller.
Please look at the file "can.h" to find the structure of CANStatus_t:
//! @brief
//! struct for a status notification from the CAN controller.
typedef struct {
uint16_t  size;					//!< size of the whole struct
uint16_t  bufftype;				//!< type of the BUFFER (CAN_BUFFER_STATUS)
uint32_t  time[2];				//!< timestamp of status change
uint8_t   res1:4;					//!< reserved
uint8_t   res2:1;					//!< reserved
uint8_t   err_passive:1;		//!< 0=error active, 1=error passive
uint8_t   err_status:1;			//!< 0=no error status, 1=error status (depends on warning limit)
uint8_t   bus_status:1;			//!< 1=bus status (CAN controller not involved in bus activity)
uint8_t   res3[3];				//!< reserved
} CANStatus_t;
Regards, Gunnar Bohlen
brutkows
Re: busoff
Post by brutkows » Fri 1. Nov 2019, 16:29
Gunnar,
Thanks for the response.
That looks like the logic I already have in can_user.c since I started with the 1_ROUTING example
If you try that example and short the FD bus, does your Router recover?
I'm using the following bit timing for a 500k/2M CANFD system:
#define _80M_500K_80____2M_80_ISO { CAN_CLOCK_80M, 4, 31, 8, 8, 96, 0, 1, 4, 7, 2, 2} // 80 MHz, 500K 80%, 2M 80%, ISO
Brian
P.Steil
Re: busoff
Post by P.Steil » Mon 4. Nov 2019, 08:20
Hello Brian,
the issue comes from the CAN controller. A status notification (a status frame) is generated to much, so the router will hang up in an endless loop. There are two solutions for that:
1) Workaround
See attached can_user.c file. Look for variable busOFF[2] and modify your code like in the file. The mod will consider only status notifications coming from a real status change. This will break the status -> re-initialize endless loop.
2) new FPGA image
Rename the ...FPGA_v4.txt file to *.bin and flash it like a firmware to the router. This is critical. Do not cycle power during the process, maybe isolate the router from your CAN bus and do this on your desk. The new CAN controller will fix the issue. After flashing is finished you need a power cycle.
can_user.c
Code for workaround
(1.81 KiB) Downloaded 675 times
PCAN-Router_FD_FPGA_v4.txt
New FPGA image, rename to *.bin
(816 KiB) Downloaded 652 times
PEAK-System HW development Team
phone: +49-6151-8173-20
fax: +49-6151-8173-29
