Cannot connect with PCAN device
afvillamil231
Re: Cannot connect with PCAN device
Post by afvillamil231 » Fri 12. Apr 2019, 14:04
output for make
make[1]: Entering directory '/home/felipe/peak-linux-driver-8.7.0/driver'
make[1]: Nothing to be done for 'depend'.
make[1]: Leaving directory '/home/felipe/peak-linux-driver-8.7.0/driver'
*** Host machine kernel version=4.18.0-17-generic
*** Driver kernel version=4.18.0-17-generic (4.18.0)
*** Path to kernel sources=/usr/src/linux-headers-4.18.0-17-generic
*** use KBUILD=yes
*** cc version=7
make -C /usr/src/linux-headers-4.18.0-17-generic  SUBDIRS=/home/felipe/peak-linux-driver-8.7.0/driver EXTRA_CFLAGS="-I/home/felipe/peak-linux-driver-8.7.0/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT  -Wno-date-time" V=0 modules
make[2]: Entering directory '/usr/src/linux-headers-4.18.0-17-generic'
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_main.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_fops.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_fifo.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_filter.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_parse.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_sja1000.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_common.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_timing.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcanfd_core.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcanfd_ucan.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_usb_core.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_usb.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_usbpro.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcanfd_usb.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_pci.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcanfd_pci.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_pciec.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_isa.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_dongle.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_pccard_core.o
  CC [M]  /home/felipe/peak-linux-driver-8.7.0/driver/src/pcan_pccard.o
  LD [M]  /home/felipe/peak-linux-driver-8.7.0/driver/pcan.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /home/felipe/peak-linux-driver-8.7.0/driver/pcan.mod.o
  LD [M]  /home/felipe/peak-linux-driver-8.7.0/driver/pcan.ko
make[2]: Leaving directory '/usr/src/linux-headers-4.18.0-17-generic'
make[1]: Entering directory '/home/felipe/peak-linux-driver-8.7.0/lib'
cc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls  -DPCANFD_OLD_STYLE_API -c src/libpcan.c -o obj/libpcan.o
cc -shared -Wl,-soname,libpcan.so.0 -o lib/libpcan.so.0.6 obj/libpcan.o
cd lib/; ln -sf libpcan.so.0.6 libpcan.so
cc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls  -DPCANFD_OLD_STYLE_API -c src/libpcanfd.c -o obj/libpcanfd.o
cc -shared -Wl,-soname,libpcanfd.so.0 -o lib/libpcanfd.so.0.1 obj/libpcanfd.o
cd lib/; ln -sf libpcanfd.so.0.1 libpcanfd.so
ar rcs lib/libpcanfd.a obj/libpcanfd.o
make[1]: Leaving directory '/home/felipe/peak-linux-driver-8.7.0/lib'
make[1]: Entering directory '/home/felipe/peak-linux-driver-8.7.0/test'
cc -DNO_RT -g -I. -I../lib -I../driver    src/receivetest.c src/common.c -lpcanfd  -L../lib/lib   -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver    src/transmitest.cpp src/common.c src/parser.cpp -lpcanfd -lstdc++  -L../lib/lib   -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver    src/bitratetest.c src/common.c -lpcanfd  -L../lib/lib   -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver    src/filtertest.cpp src/common.c -lpcanfd -lstdc++  -L../lib/lib   -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver    src/pcanfdtst.c -lpcanfd  -L../lib/lib   -o pcanfdtst
cc -DNO_RT -g -I. -I../lib -I../driver    src/pcan-settings.c -lpopt  -L../lib/lib   -g -o pcan-settings
make[1]: Leaving directory '/home/felipe/peak-linux-driver-8.7.0/test'
Reason: Format applied for better reading
Post by M.Maidhof » Fri 12. Apr 2019, 14:56
next step:
sudo make install
sudo modprobe pcan
afvillamil231
Post by afvillamil231 » Fri 12. Apr 2019, 15:06
Yes I have already done all the steps, I have told you three times......
sudo make install
Info: /lib/modules/4.18.0-17-generic/misc exists.
Info: Left current 'pcan'-entry in /etc/modprobe.d/pcan.conf untouched.
Info: Copied 45-pcan.rules to /etc/udev/rules.d.
Info: mainline drivers removed and blacklisted in
      /etc/modprobe.d/blacklist-peak.conf
mkdir -p /usr/lib
cp -d lib/* /usr/lib
if [ -d lib32 ]; then \
	mkdir -p /usr/lib32; \
	cp -d lib32/* /usr/lib32; \
fi
mkdir -p /usr/include
chmod 644 libpcan.h libpcanfd.h
cp libpcan.h libpcanfd.h /usr/include
/sbin/ldconfig
cp receivetest transmitest bitratetest filtertest pcanfdtst pcan-settings /usr/local/bin
sudo modprobe pcan
modprobe: ERROR: could not insert 'pcan': Operation not permitted
modprobe: ERROR: ../libkmod/libkmod-module.c:979 command_do() Error running install command for pcan
Post by M.Maidhof » Fri 12. Apr 2019, 15:13
if I ask for outputs, and you don´t send them completly, and later you write to me that you did it already three times, I think it is time to not answer anymore to your problem, until you change your behaviour....
think about it, before asking for free support for a third party application....
afvillamil231
Post by afvillamil231 » Fri 12. Apr 2019, 16:15
Sorry if I have been rough. I just felt you were asking me the same thing for a while and like not reading. I am sorry anyway.
Well, as information, I solved the problem! So, the modprobe did not accept the pcan operation because the Secure boot system does not give it the right permissions. In order to let the modprobe finish the driver installation, you have to disable the Secure boot from your computer. The solution was taken from here https://github.com/openrazer/openrazer/issues/677
Finally what I did was:
1. restart my pc from the boot set up
2. change the Secure boot option to disable
3. Go to linux again
4. make clean -> make -> sudo make install -> sudo modprobe pcan
So the output to cat /proc/pcan is now
*------------- Release_20181116_n (8.7.0) Apr 12 2019 16:03:30 --------------
*--------------------- 1 interfaces @ major 237 found -----------------------
32    usb   -NA- ffffffff 015 0x001c 00000000 00000000 00000000 00000000 0x0000
Thank you for your time and your support! I will ask again if I have more questions.
Kind regards,
Felipe
noorulj@gmail.com
Post by noorulj@gmail.com » Mon 11. Nov 2019, 07:55
I too had similar issue of modprobe not finding pcan device. After disabling secure boot it worked for me..
PCAN device was getting detected till i restarted my Ubuntu system. Once i restarted it is again not working.
when i do
sudo modprobe pcan
i get the below errors...
modprobe: ERROR: ../libkmod/libkmod-module.c:832 kmod_module_insert_module() could not find module by name='pcan'
modprobe: ERROR: could not insert 'pcan': Unknown symbol in module, or unknown parameter (see dmesg)
modprobe: ERROR: ../libkmod/libkmod-module.c:977 command_do() Error running install command for pcan
i run lsusb, i could see
Bus 001 Device 046: ID 0c72:0014 PEAK System
Bus 001 Device 045: ID 0c72:0014 PEAK System
Bus 001 Device 044: ID 0c72:0014 PEAK System
Bus 001 Device 043: ID 0c72:4062 PEAK System
dmesg after running modprobe
[250267.615236] usb 1-5: new full-speed USB device number 48 using xhci_hcd
[250308.484481] usb 1-5: new full-speed USB device number 52 using xhci_hcd
[250332.049207] usb 1-5: new full-speed USB device number 54 using xhci_hcd
[250332.161217] usb 1-5: device descriptor read/64, error -71
[250351.729810] usb 1-5: new full-speed USB device number 57 using xhci_hcd
[250366.982214] usb 1-5: new full-speed USB device number 59 using xhci_hcd
[250369.394296] usb 1-5: new full-speed USB device number 60 using xhci_hcd
[250376.338538] usb 1-5: new full-speed USB device number 61 using xhci_hcd
[250376.450557] usb 1-5: device descriptor read/64, error -71
[250383.014737] usb 1-5: new full-speed USB device number 62 using xhci_hcd
[250383.126766] usb 1-5: device descriptor read/64, error -71
[250391.687004] usb 1-5: new full-speed USB device number 64 using xhci_hcd
[250405.771437] usb 1-5: new full-speed USB device number 68 using xhci_hcd
[250419.583841] usb 1-5: new full-speed USB device number 70 using xhci_hcd
If i reinstall the driver it might start working.. But then i need to know that , do i have to reinstall everytime i restart the system
Reason: Inserted [code] tags for improved readability
Post by M.Maidhof » Mon 11. Nov 2019, 13:30
you have to build and install the pcan driver with each kernel update. If you use the kernel integrated SocketCAN driver instead, you don't have to rebuild the driver with each kernel update.
So if you want to use SocketCAN, simply uninstall our pcan driver again and reboot your system once, to have the kernel driver active again.
