How To Stop A Loop With Respect To Time
Universal Controller for CAN Applications
yhadad
Post by yhadad » Wed 20. Nov 2019, 22:22
I am currently controlling a shift actuator that is also giving me position feedback in PWM signal. It works great by using my PCAN-MIO and an H-Bridge. I can control the shift actuator to turn in one direction and stop until it reaches a specific position based on the reading of the position sensor feedback. Here is the loop that I am using below. The only challenge that I have is that:
1) I also need to stop this loop with respect to time in 200ms in case it does not reach the target position due to gear clash. I want to add that logic so that I do not burn the shift actuator motor.
2) I would also like to set a condition to stop the loop if the current sense feedback exceeds a current limit.
'Start loop logic
  PrintToOutputWindow "Now start LOOP..."
 'Safety Condition Shift Range Limit Detector
     Var13.Value = 1
    PrintToOutputWindow "value set to : " & CStr(CInt(Var13.Value))
    Wait(1000)
    If Var14.Value > 730 Then
       MsgBox "Shift Actuator is out of shift range",,"Error"
       Exit Sub
    Elseif Var14.Value => 695.1 Then
       MsgBox "Shift Actuator is already in 4 Low position",,"Error"
       Exit Sub
    Elseif Var14.Value <= 220 Then
       Exit Sub
    End If
    'Start Shift
    If Var14.Value < 695 then
    Var15.Value = 1
    PrintToOutputWindow "value set to : " & CStr(CInt(Var15.Value))
    Var20.Value = 1
    PrintToOutputWindow "value set to : " & CStr(CInt(Var20.Value))
    Do until Var14.Value > 695
    loop
    Var15.Value = 0
    Wait(10)
    Var20.Value = 0
    Exit sub
    End if
I have tried several codes but had no success to Exit/ End Do loop :(
Can you please help?
Re: How To Stop A Loop With Respect To Time
Post by M.Heidemann » Thu 21. Nov 2019, 10:22
The code you included looks like VBS, which leads to the question:
Since using PPCAN-Editor is the only way to program the PCAN-MIO,
How are you using VBS to control the PCAN-MIO?
Are you using PCAN-Explorer 6 here as well?
Please clarify how your current setup looks like and how you are using it.
yhadad
Post by yhadad » Thu 21. Nov 2019, 15:47
Hello Marvin,
I am using VBS that is in PCAN-Explorer 6. If you like, I can email you the .pem file so that you can see the entire code if that helps?
Post by M.Heidemann » Fri 22. Nov 2019, 11:37
To use a value (of a signal for example) as a break-condition you could use a While-Loop, for example:
Sub WaitForValue()
Value = 1
    Do while Value < 156
     PrintToOutputWindow Value
     Value = Value + 1 'This simulates the value rising'
    Wait 1
    loop
 PrintToOutputWindow "Limit was reached "
 End Sub
You could also use the function GetSystemTime, like this:
Sub TestTimeWhile()
 Dim client, starttime, currenttime, timediff
     Set client = Connections(1).CommunicationObject.Parent
     startime = client.GetSystemTime
       Do while timediff < 200
         currenttime = client.GetSystemTime
         timediff = currenttime - starttime
         PrintToOutputWindow currenttime
         Wait 1
       PrintToOutputWindow "Done"
       Wait 1
    loop
End Sub
Note: You need an active connection to use "GetSystemTime" in your script.
GetSystemTime is a function of the PCANClient object.
Also note:
If you use "PrintToOutputWindow" in a loop like you do it will slow down the whole script,
preferably you initate a wait of 1 to prevent lockups.
You could also combine those two concepts like this:
Sub TimeAndValue()
    Do until YourVariable.Value > 695
       If currenttime - starttime >= 200 Then
         Exit Do
       End If
       Wait 1
    loop
End Sub
yhadad
Post by yhadad » Mon 25. Nov 2019, 19:46
Thank you Marvin,
Your codes worked for adding time limit and reaching a limit value as well. I also added "Wait 1" to the rest of my script as you had suggested and things are running much better now :)
I just wanted to see if I understood you correctly about your note below:
M.Heidemann wrote:Note: You need an active connection to use "GetSystemTime" in your script.
Do you mean that I need to be connected to a Peak hardware such as PCAN-USB? or do you mean something else?
Reason: Quote formatting for better reading
Post by M.Heidemann » Tue 26. Nov 2019, 08:42
You need the PCANClient object present.
The PCANClient object can be accessed by using the CommunicationObject property of the Connection object.
It also can be a virtual connection, if that is the case hardware does not have to be attached for this to work.
It represents an interface between PCAN-Explorer 6 and the CAN bus.
If you take a look at the PCAN-Explorer 6 documentation and search for "PCANClient Object" you will see, what the PCANClient "GetSystemTime" referenced as one of it's methods.
