Error- 'write: No buffer space available' | driver-8.9.3
JeyP4
Post by JeyP4 » Mon 9. Dec 2019, 17:03
I bought PCAN's CAN-USB cable.
And modified 'interface' to Setup the networking rules.
sudo gedit /etc/network/interfaces
////////////    'interfaces' file
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto can0
iface can0 inet manual
	#pre-up ip link set $IFACE type can bitrate 125000 listen-only off
	pre-up /sbin/ip link set $IFACE type can bitrate 125000 triple-sampling on
	up /sbin/ifconfig $IFACE up
	down /sbin/ifconfig $IFACE down
Problem is when I sending canmsg with cangen(cangen -g 1 -I i can0 -v), it stops after 446 messages.
I installed latest 'peak-linux-driver-8.9.3'.
Installation commands were:
cd peak-linux-driver-8.9.3
make clean
cd driver/
make clean
make NET=NETDEV_SUPPORT
sudo make install
After latest driver installation
jai@jai:~$ cat /proc/pcan
*------------- Release_20191029_n (8.9.3) Dec  9 2019 16:35:25 --------------
*--------------------- 1 interfaces @ major 240 found -----------------------
32    usb   can0 ffffffff 254 0x031c 00000000 00000000 0000044d 00000000 0x0000
jai@jai:~$ uname -a
Linux jai 4.15.0-72-generic #81~16.04.1-Ubuntu SMP Tue Nov 26 16:34:21 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
My doubt: if I attach real sensor, will CANBUS stop entertaining new sensor msgs after certain number of msgs?
Re: Error- 'write: No buffer space available' | driver-8.9.3
Post by M.Maidhof » Mon 9. Dec 2019, 17:20
do you have another active CAN node (125k bitrate) connected to the PCAN-USB, and your CAN cables are terminated on both ends?
JeyP4
Post by JeyP4 » Mon 9. Dec 2019, 17:25
M.Maidhof wrote:Hi,
Oh.
Right now I just connected the CAN-USB cable to host PC.
Do you think if there is another CAN node with proper terminated CANBUS, this issue would resolve?
If yes, then I would try as soon as I receive my sensor. Can you brief why it says 'No buffer space available' after 446 canmsgs when only host-PC is connected?
Post by M.Maidhof » Mon 9. Dec 2019, 17:48
yes, a CAN system needs at least 2 active nodes, otherwise the CAN controller will get no ack, and will resend the last message again and again, while the transmit buffer will overflow due to the active cangen.
JeyP4
Post by JeyP4 » Mon 9. Dec 2019, 18:07
Thanks I will try soon and reply.
