My frame is going out, each time I set a variable
davidsoco
Post by davidsoco » Wed 3. Oct 2012, 16:40
I would like prepare the content of a frame, and then send it out.
I'm using a panel, in which I set virtual variables with my values. when I click on the a send button I copy the virtual var into the frame var like this
Sub SendBus1()
   dim symbols
   set symbols = SymbolsManager("CanOpenTester")
   Signals("SdoReqData0").Value = Signals("SDOTmpReq0").Value
   Signals("SdoReqData1").Value = Signals("SDOTmpReq1").Value
   Signals("SdoReqData2").Value = Signals("SDOTmpReq2").Value
   Signals("SdoReqData3").Value = Signals("SDOTmpReq3").Value
   Signals("SdoReqIndex").Value = Signals("SDOTmpReqIndex").Value
   Signals("SdoReqSubIndex").Value = Signals("SDOTmpReqSubIndex").Value
   symbols("SDOReq").DefaultMultiplexer.Send (Signals("CanBus").Value)
End Sub
my problem is that the frame is output 7 times when I click on send (ones per "set" of variable)
Want is the right solution to output the frame only at the end ?
thanks
K.Wolf
Re: My frame is going out, each time I set a variable
Post by K.Wolf » Thu 4. Oct 2012, 10:52
This auto-transmit behavior enabled by default. You can switch it off, but you have to do it for each variable separately:
Signals("SdoReqData0").Source.AutoTransmit = False
Signals("SdoReqData1").Source.AutoTransmit = False
Signals("SdoReqData2").Source.AutoTransmit = False
Signals("SdoReqData3").Source.AutoTransmit = False
Signals("SdoReqIndex").Source.AutoTransmit = False
Signals("SdoReqSubIndex").Source.AutoTransmit = False
If you leave the AutoTransmit property enabled for the last variable SdoReqSubIndex, assigning the last value will send the frame once and you can omit the separate call of the Multiplexer.Send method.
