EMC testing
CAN to LAN gateway in DIN rail plastic casing
liviu2004
EMC testing
Post by liviu2004 » Mon 13. Jan 2020, 15:33
Hi PEAK Systems.
Can you please confirm if the PCAN-Ethernet Gateway DR is designed according marine bridge EMC environment? There are several applications where your product might be used but compliance with the rules is unclear.
As per attached document, Section 22, 23, 24, 25, 26, 27 but especially 29 and 30 for equipment on the bridge zone.
Thanks.
Test_Specification_Number_1.pdf
(506.97 KiB) Downloaded 5228 times
Re: EMC testing
Post by M.Heidemann » Mon 13. Jan 2020, 15:42
It is not. There were no tests done according to the marine bridge EMC environment specification.
liviu2004
Re: EMC testing
Post by liviu2004 » Wed 29. Jan 2020, 15:48
Thanks for the response. In the meantime, two vessels had to remove these units, unfortunate. Maybe PEAK will consider testing for marine, could be that the equipment design might be compliant already.
Re: EMC testing
Post by M.Maidhof » Wed 29. Jan 2020, 16:57
please contact us by email with your request. Our EMC specialists can check the effort and send you an offer for such an EMC test for those products.
