Hello everybody,
I have a PCAN-Ethernet Gateway DR (IP 192.168.1.10) and I want to connect it with my PC, with the Virtual PCAN Gateway (IP 192.168.1.11) over an Ethernet cable.
I connect my CAN-Device (a ball bearing with integrated sensors) with the Channel 1 at the Gateway.
I definied the routes like it is described in the User Manual.
The problem is, that I always get the error, that the route is active, but not connected with the remote side (yellow/orange LED).
I am sure, that I connected my device correctly.
I just want to recieve messages (the sensor values from the ball bearing) , but i don`t get any values in the PCAN Viewer.
I tried different things, like the other channel, UDP instead of TCP, different IP adresses, bit rates, ports etc.
I hope that somebody could help me.
Thannk you and best regards!
Gastuser123
Receiving no messages from CAN Device at the PC
Re: Receiving no messages from CAN Device at the PC
Please send us your configuration file (.ini) to support[at]peak-system.com and a detailed description of the setup used. Also make sure that the CAN-bus side of the chain is properly terminated.
