Critical defect pcan.h pollutes DWORD on Ubuntu to 64 bits
Fojtik
Post by Fojtik » Fri 31. Jan 2020, 12:25
I have found a critical issue.
typedef __signed__ int __s32;
typedef unsigned int __u32;
this __u32 has size 64 bit and not 32 bit.
pcan.h forces:
#else
#define DWORD  __u32
#define WORD   __u16
#define BYTE   __u8
#endif
DWORD to 64 bit int and it corrupts my code. Is there any way how to get out from this unwanted mess?
pcan.h
Standard Peak include header.
(8.84 KiB) Downloaded 318 times
int-ll64.h
Definition of __u32 in Ubuntu.
(801 Bytes) Downloaded 306 times
S.Grosjean
Re: Critical defect pcan.h pollutes DWORD on Ubuntu
Post by S.Grosjean » Fri 31. Jan 2020, 12:40
Please first give us the error "message" you're just talking about. This would be very helpful to better help you.
Next:
$ uname -a
Linux linux-dev 5.3.0-19-generic #20-Ubuntu SMP Fri Oct 18 09:04:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
$ cat sizeof.c
#include <stdio.h>
int main(int argc, char *argv[])
        printf("sizeof(unsigned char)=%lu\n", sizeof(unsigned char));
        printf("sizeof(unsigned short)=%lu\n", sizeof(unsigned short));
        printf("sizeof(unsigned int)=%lu\n", sizeof(unsigned int));
        printf("sizeof(unsigned long)=%lu\n", sizeof(unsigned long));
        return 0;
$ gcc sizeof.c -o sizeof
$ ./sizeof
sizeof(unsigned char)=1
sizeof(unsigned short)=2
sizeof(unsigned int)=4
sizeof(unsigned long)=8
Fojtik
Re: Critical defect pcan.h pollutes DWORD on Ubuntu to 64 bits
Post by Fojtik » Fri 31. Jan 2020, 12:54
The header pcan.c is from 2010.
C standard 2011 define these types:
https://pubs.opengroup.org/onlinepubs/0 ... int.h.html
https://en.cppreference.com/w/cpp/types/integer
The following types are required:
int8_t
int16_t
int32_t
uint8_t
uint16_t
uint32_t
Fojtik
Post by Fojtik » Fri 31. Jan 2020, 13:04
It seems that there is something more weird:
  printf("__u32 %ld __u16 %ld __u8 %ld\n", sizeof(__u32), sizeof(__u16), sizeof(__u8));
__u32 8 __u16 2 __u8 1
Fojtik
Post by Fojtik » Fri 31. Jan 2020, 13:30
Excuse me, another header collided with DWORD. Now seems everything OK.
__u32 4 __u16 2 __u8 1
This thread could be erased not to confuse others.
Post by PEAK-Support » Fri 31. Jan 2020, 23:11
This is NOT the first time that you post „errors“ and talk about „bug“and „problems“ and at the end you are the problem and you waste our time. See also this post post
Please think before you write and try first to find your own problems before post it here.
