Binary data file not supported from Hardware
4-Channel CAN Router with Data Logger
ckessle2
Post by ckessle2 » Thu 20. Feb 2020, 12:42
Win 10 enterprise Version 1909
PeakDriver 4.2.0.16376
PCANFlash and PCAN-Router Pro connected on CAN1 via PCAN-USB pro
I want to program the router (I did this last year, now I have a new notebook)
Start PCAN-Flash
Connect
(find PCAN-USB pro)
select Channel 1
Detect module
(module no 15 FlashType LPC_IAP Version 1.00 Date 6.6.2013 Modus active Status ok)
activate
(all 8 channel LED are blinking, CF card and mjuC are off Power is on)
then download (green arrow)
Loading file "..\Examples\0_Odometry\.out\example_can.bin" ...
Calculate CRC with file length 253952 ...
Checking BIN file...
Always same MEssage "Binary Data file not supported from Hardware"
Then I tried with rotary switch set to F and bootloading
(module no 15 FlashType LPC_IAP Version 2.03 Date 23.9.2011 Modus active Status ok)
Loading file "..\Bootloader update v1.x to v2.0\BootloaderUpdateV2.0.bin" ...
Christoph
Re: Binary data file not supported from Hardware
Post by M.Heidemann » Thu 20. Feb 2020, 12:59
Hello Christoph,
Please download the PCAN-Router Pro Dev Package:
https://www.peak-system.com/fileadmin/m ... ro_dev.zip
"Make" one of the examples and try the procedure again.
Please tell me your results.
ckessle2
Post by ckessle2 » Mon 2. Mar 2020, 11:26
Dear Marvin,
following your suggestions I could again Programm my PEak router. I guess it was a combinbation of some old libs which compiled fine but did not load. No all is fine
You can close my issue now.
Thank you! - always nice to get efficient help from Peak in an easy way.
Christoph
