I bought PCAN-USB and PCAN-USB X6, and I'm trying to use them in Raspberry Pi 3B+.
I installed the linux driver (netdev mode) according to the following page.
viewtopic.php?t=3381
There's no problem with PCAN-USB, but PCAN-USB X6 doesn't work.
The external power supply(12V) is connected, and the LED status looks OK,
but it never shows up in 'ifconfig -a'.
Here's the log message.
Any tips for this issue?
Of course, the USB cable is connected.
pi@rasp0812:/proc $ dmesg | grep pcan
[ 103.070064] pcan: loading out-of-tree module taints kernel.
[ 103.074927] pcan: Release_20191029_n (le)
[ 103.074942] pcan: driver config [mod] [usb] [net]
[ 103.075927] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 103.076654] pcan: PCAN-USB X6 channel 1 device number=0
[ 103.077459] pcan: registered CAN-FD netdevice can0 for usbfd hw (240,32)
[ 103.077475] pcan: usb device minor 32 found
[ 103.078401] pcan: PCAN-USB X6 channel 2 device number=0
[ 103.079276] pcan: registered CAN-FD netdevice can1 for usbfd hw (240,33)
[ 103.079285] pcan: usb device minor 33 found
[ 103.079416] usbcore: registered new interface driver pcan
[ 103.079430] pcan: major 240.
[ 103.090785] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 104.543936] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 104.546525] pcan: PCAN-USB X6 channel 1 device number=0
[ 104.547034] pcan: registered CAN-FD netdevice can0 for usbfd hw (240,32)
[ 104.547041] pcan: usb device minor 32 found
[ 104.547665] pcan: PCAN-USB X6 channel 2 device number=0
[ 104.548462] pcan: registered CAN-FD netdevice can1 for usbfd hw (240,33)
[ 104.548474] pcan: usb device minor 33 found
[ 104.607694] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 157.616483] pcan: PCAN-USB fw v8.4
[ 157.668261] pcan: PCAN-USB channel device number=255
[ 157.668789] pcan: registered CAN netdevice can0 for usb hw (240,32)
[ 157.668796] pcan: usb device minor 32 found
[ 200.451032] pcan: err -19 submitting cmd 3.2 to PCAN-USB
[ 200.451041] pcan: err -19 submitting cmd 11.2 to PCAN-USB
[ 204.409048] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 204.410653] pcan: PCAN-USB X6 channel 1 device number=0
[ 204.411490] pcan: registered CAN-FD netdevice can0 for usbfd hw (240,32)
[ 204.411500] pcan: usb device minor 32 found
[ 204.419620] pcan: PCAN-USB X6 channel 2 device number=0
[ 204.420688] pcan: registered CAN-FD netdevice can1 for usbfd hw (240,33)
[ 204.420700] pcan: usb device minor 33 found
[ 204.470931] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 205.893951] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 205.894683] pcan: PCAN-USB X6 channel 1 device number=0
[ 205.895266] pcan: registered CAN-FD netdevice can0 for usbfd hw (240,32)
[ 205.895275] pcan: usb device minor 32 found
[ 205.895924] pcan: PCAN-USB X6 channel 2 device number=0
[ 205.896624] pcan: registered CAN-FD netdevice can1 for usbfd hw (240,33)
[ 205.896630] pcan: usb device minor 33 found
[ 205.954537] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 207.353970] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 207.354647] pcan: PCAN-USB X6 channel 1 device number=0
[ 207.355233] pcan: registered CAN-FD netdevice can0 for usbfd hw (240,32)
[ 207.355239] pcan: usb device minor 32 found
[ 207.355847] pcan: PCAN-USB X6 channel 2 device number=0
[ 207.356627] pcan: registered CAN-FD netdevice can1 for usbfd hw (240,33)
[ 207.356638] pcan: usb device minor 33 found
[ 207.412769] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 208.824962] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 208.826142] pcan: PCAN-USB X6 channel 1 device number=0
[ 208.827173] pcan: registered CAN-FD netdevice can0 for usbfd hw (240,32)
[ 208.827184] pcan: usb device minor 32 found
[ 208.828150] pcan: PCAN-USB X6 channel 2 device number=0
[ 208.829109] pcan: registered CAN-FD netdevice can1 for usbfd hw (240,33)
[ 208.829119] pcan: usb device minor 33 found
[ 208.883036] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 273.135471] usbcore: deregistering interface driver pcan
[ 273.135602] pcan: removed.
[ 551.219699] pcan: Release_20191029_n (le)
[ 551.219714] pcan: driver config [mod] [usb]
[ 551.219890] usbcore: registered new interface driver pcan
[ 551.219913] pcan: major 240.
[ 562.543549] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 562.544394] pcan: PCAN-USB X6 channel 1 device number=0
[ 562.544527] pcan: usb device minor 32 found
[ 562.545259] pcan: PCAN-USB X6 channel 2 device number=0
[ 562.545459] pcan: usb device minor 33 found
[ 562.584505] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 563.863546] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 563.864264] pcan: PCAN-USB X6 channel 1 device number=0
[ 563.864402] pcan: usb device minor 32 found
[ 563.865058] pcan: PCAN-USB X6 channel 2 device number=0
[ 563.865253] pcan: usb device minor 33 found
[ 563.921112] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 565.193165] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 565.193973] pcan: PCAN-USB X6 channel 1 device number=0
[ 565.194103] pcan: usb device minor 32 found
[ 565.195053] pcan: PCAN-USB X6 channel 2 device number=0
[ 565.195228] pcan: usb device minor 33 found
[ 565.249513] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 585.200225] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 585.200871] pcan: PCAN-USB X6 channel 1 device number=0
[ 585.201011] pcan: usb device minor 32 found
[ 585.201628] pcan: PCAN-USB X6 channel 2 device number=0
[ 585.201781] pcan: usb device minor 33 found
[ 585.252698] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 589.284023] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 589.285579] pcan: PCAN-USB X6 channel 1 device number=0
[ 589.285767] pcan: usb device minor 32 found
[ 589.287251] pcan: PCAN-USB X6 channel 2 device number=0
[ 589.287397] pcan: usb device minor 33 found
[ 589.327986] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 619.669268] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 619.670264] pcan: PCAN-USB X6 channel 1 device number=0
[ 619.670379] pcan: usb device minor 32 found
[ 619.671306] pcan: PCAN-USB X6 channel 2 device number=0
[ 619.671523] pcan: usb device minor 33 found
[ 619.721734] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 621.009226] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 621.010127] pcan: PCAN-USB X6 channel 1 device number=0
[ 621.010226] pcan: usb device minor 32 found
[ 621.011136] pcan: PCAN-USB X6 channel 2 device number=0
[ 621.011348] pcan: usb device minor 33 found
[ 621.062756] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 622.329196] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 622.330155] pcan: PCAN-USB X6 channel 1 device number=0
[ 622.330299] pcan: usb device minor 32 found
[ 622.331145] pcan: PCAN-USB X6 channel 2 device number=0
[ 622.331347] pcan: usb device minor 33 found
[ 622.382036] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 623.659253] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 623.659982] pcan: PCAN-USB X6 channel 1 device number=0
[ 623.660110] pcan: usb device minor 32 found
[ 623.660785] pcan: PCAN-USB X6 channel 2 device number=0
[ 623.660966] pcan: usb device minor 33 found
[ 623.713031] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 624.989164] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 624.989889] pcan: PCAN-USB X6 channel 1 device number=0
[ 624.990025] pcan: usb device minor 32 found
[ 624.990719] pcan: PCAN-USB X6 channel 2 device number=0
[ 624.990901] pcan: usb device minor 33 found
[ 625.043019] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 626.319594] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 626.320637] pcan: PCAN-USB X6 channel 1 device number=0
[ 626.320727] pcan: usb device minor 32 found
[ 626.323146] pcan: PCAN-USB X6 channel 2 device number=0
[ 626.323319] pcan: usb device minor 33 found
[ 626.364118] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 660.147316] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 660.147823] pcan: PCAN-USB X6 channel 1 device number=0
[ 660.147951] pcan: usb device minor 32 found
[ 660.148443] pcan: PCAN-USB X6 channel 2 device number=0
[ 660.148615] pcan: usb device minor 33 found
[ 660.190495] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 751.298752] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 751.299574] pcan: PCAN-USB X6 channel 1 device number=0
[ 751.299700] pcan: usb device minor 32 found
[ 751.300610] pcan: PCAN-USB X6 channel 2 device number=0
[ 751.300808] pcan: usb device minor 33 found
[ 751.350730] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 844.174085] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 844.178817] pcan: PCAN-USB X6 channel 1 device number=0
[ 844.178880] pcan: usb device minor 32 found
[ 844.179449] pcan: PCAN-USB X6 channel 2 device number=0
[ 844.179594] pcan: usb device minor 33 found
[ 844.229213] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 845.523666] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 845.524288] pcan: PCAN-USB X6 channel 1 device number=0
[ 845.524401] pcan: usb device minor 32 found
[ 845.524938] pcan: PCAN-USB X6 channel 2 device number=0
[ 845.525108] pcan: usb device minor 33 found
[ 845.578531] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 846.853817] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 846.854522] pcan: PCAN-USB X6 channel 1 device number=0
[ 846.854639] pcan: usb device minor 32 found
[ 846.855265] pcan: PCAN-USB X6 channel 2 device number=0
[ 846.855425] pcan: usb device minor 33 found
[ 846.909778] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1242.484151] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 1242.485136] pcan: PCAN-USB X6 channel 1 device number=0
[ 1242.485222] pcan: usb device minor 32 found
[ 1242.486153] pcan: PCAN-USB X6 channel 2 device number=0
[ 1242.486383] pcan: usb device minor 33 found
[ 1242.726330] pcan: PCAN-USB X6 channel 3 device number=0
[ 1242.726448] pcan: usb device minor 34 found
[ 1242.727313] pcan: PCAN-USB X6 channel 4 device number=0
[ 1242.727513] pcan: usb device minor 35 found
[ 1242.976536] pcan: PCAN-USB X6 channel 5 device number=0
[ 1242.976636] pcan: usb device minor 36 found
[ 1242.977483] pcan: PCAN-USB X6 channel 6 device number=0
[ 1242.977693] pcan: usb device minor 37 found
[ 1243.899647] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1243.899684] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1243.899693] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1245.043412] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 1245.044055] pcan: PCAN-USB X6 channel 1 device number=0
[ 1245.044167] pcan: usb device minor 32 found
[ 1245.044716] pcan: PCAN-USB X6 channel 2 device number=0
[ 1245.044877] pcan: usb device minor 33 found
[ 1245.077881] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1246.373239] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 1246.373760] pcan: PCAN-USB X6 channel 1 device number=0
[ 1246.373875] pcan: usb device minor 32 found
[ 1246.374318] pcan: PCAN-USB X6 channel 2 device number=0
[ 1246.374508] pcan: usb device minor 33 found
[ 1246.604827] pcan: PCAN-USB X6 channel 3 device number=0
[ 1246.604946] pcan: usb device minor 34 found
[ 1246.605427] pcan: PCAN-USB X6 channel 4 device number=0
[ 1246.605591] pcan: usb device minor 35 found
[ 1246.698166] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1246.698194] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1247.954228] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 1247.955213] pcan: PCAN-USB X6 channel 1 device number=0
[ 1247.955299] pcan: usb device minor 32 found
[ 1247.956200] pcan: PCAN-USB X6 channel 2 device number=0
[ 1247.956402] pcan: usb device minor 33 found
[ 1248.186213] pcan: PCAN-USB X6 channel 3 device number=0
[ 1248.186354] pcan: usb device minor 34 found
[ 1248.187258] pcan: PCAN-USB X6 channel 4 device number=0
[ 1248.187454] pcan: usb device minor 35 found
[ 1248.193002] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1248.193024] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1249.444182] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 1249.445023] pcan: PCAN-USB X6 channel 1 device number=0
[ 1249.445153] pcan: usb device minor 32 found
[ 1249.445851] pcan: PCAN-USB X6 channel 2 device number=0
[ 1249.446029] pcan: usb device minor 33 found
[ 1249.676328] pcan: PCAN-USB X6 channel 3 device number=0
[ 1249.676470] pcan: usb device minor 34 found
[ 1249.677346] pcan: PCAN-USB X6 channel 4 device number=0
[ 1249.677530] pcan: usb device minor 35 found
[ 1249.679426] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1249.679440] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1250.924301] pcan: PCAN-USB X6 (01h PCB03h) fw v3.2.0 bl v1.1.0
[ 1250.925242] pcan: PCAN-USB X6 channel 1 device number=0
[ 1250.925344] pcan: usb device minor 32 found
[ 1250.926335] pcan: PCAN-USB X6 channel 2 device number=0
[ 1250.926524] pcan: usb device minor 33 found
[ 1251.144273] pcan: err -71 when reading: is PCAN-USB X6 usb cable disconnected?
[ 1332.317444] usbcore: deregistering interface driver pcan
[ 1332.319752] pcan: removed.
[ 1677.765991] pcan: Release_20191029_n (le)
[ 1677.766003] pcan: driver config [mod] [usb] [net]
[ 1677.766185] usbcore: registered new interface driver pcan
[ 1677.766209] pcan: major 240.
