Change of Active Window
Krishna.skt
Post by Krishna.skt » Sun 24. May 2020, 16:50
I was trying to make different files active at a different time. To be more specific, i want to make .ipf file(window) active after certain time my macro has started and Change it later again. I mean, I want to see my .ipf file as a active window for a certain period of time and later back to my original .pem file. How can i achieve this. I tried different methods from help section but i could not achieve the required result.
Thank you in Advance.
Re: Change of Active Window
Post by M.Heidemann » Mon 25. May 2020, 15:04
Hello Krishna,
You can try the following example, if your document is open you can do this:
Sub IsActiveExample()
   Dim myDocument
	Set MyDocument = Documents("YourExampleDocument.Doc")
	myDocument.ActiveWindow.IsActive = True
End Sub
Where "YourExampleDocument.Doc" is the name of the document you want to switch to.
So, first switch to the desired .ipf and after X seconds (You could use the "Wait" function) switch back to your .pem.
