RP1210_SendMessage & SendCommand question
RP1210 Development Package and RP1210 Connectivity to PEAK CAN Interfaces
Wayne
Post by Wayne » Wed 27. May 2020, 14:52
I’m using the USB-CAN adapter with the RP1210-C driver, when calling the send message function I’m getting an error 159 ERR_MESSAGE_NOT_SENT, also when using the send command function to set CAN broadcast I’m getting a 141 ERR_MESSAGE_TOO_LONG. I have used the code with other RP1210 adapters before.
Any advice would be gratefully received.
System:
Win 10
PEAKRP32.dll RP1210 C (32 bit) version - 2.0.3.210
USB firmware 8.4
Thanks Wayne
Re: RP1210_SendMessage & SendCommand question
Post by M.Heidemann » Wed 27. May 2020, 15:32
Hello Wayne,
Thank you for your request.
You use an older version of the RP1210-C API, please take a look at the change history here:
https://www.peak-system.com/PCAN-RP1210-C.361.0.html
Please contact us via e-mail (with your RP-1210-C serial number) to receive an update:
