Unable to listen only mode in pcan-view in ubuntu 16.04
I have pcan driver running and now im trying to listen by installing pcan-view. But, the pop up box does not allow me to listen to the messages. see picture:
- S.Grosjean
- Software Development
Re: Unable to listen only mode in pcan-view in ubuntu 16.04
AFAIU you try with pcanview to watch the CAN bus through a device that is already in use by another application (see the "Already in use" message). Changing the settings of an opened device is not possible. Moreover, the pcan driver is not able to forward the CAN frames read from the CAN bus to several clients at the same time.
— Stéphane
