VirtualBox Linux guest not seeing can0
I am new to Linux, am trying to utilize an existing application that uses the PCAN-USB adapter. The application is in CentOs running as guest on Windows host platform on VirtualBox 5.20. Do I need to install Windows drivers to "pass thru" the USB connection as CAN to the guest OS so the udev picks it up and sees a /dev/can? Or is this something that building/loading the Peak Linux drivers (and rebuilding) in the guest Linux system will do? Was looking for some concrete steps to take. Thanks in advance.
Re: VirtualBox Linux guest not seeing can0
there is no need to install the windows drivers, if you want to use the PCAN-USB in the Linux VM. Please check with lsusb if the PCAN-USB is correctly recognized in the VM system. If not, please update your VirtualBox to latest version 6.x first.
