not detecting PCAN USB hardware in PCAN view
USB to CAN Interface
ujjwal tambe
Post by ujjwal tambe » Sat 24. Nov 2018, 06:27
I have purchased PCAN USB hardware for my project. I installed PCAN view tool so in tool itself my CAN USB hardware is not detecting. Please help me with this. Do I need to install any other software?
Screenshot (142).png (117.19 KiB) Viewed 12397 times
Re: not detecting PCAN USB hardware in PCAN view
Post by M.Maidhof » Mon 26. Nov 2018, 10:22
did you install the driver with the driver setup PeakOemDrv.exe? What is displayed in the device manager of Windows?
liquidcable
Post by liquidcable » Fri 17. Jul 2020, 17:53
I have the same problem and I did install the driver but I connected the device before I installed the driver. Device Manager lists the driver as from FTDI.
Post by M.Heidemann » Mon 20. Jul 2020, 09:27
Can you please tell us, which PCAN-Device you are using?
Please also tell us the serial-number of your device.
mb-86
Post by mb-86 » Wed 22. Jul 2020, 14:42
Hi there,
seems like I have a similar issue.
Using IPEH-002022 with a SN > 200000
When connecting to USB on my laptop, the LED blinks red once for a very short time. Afterwards: nothing.
The device manager does not show any changes. No device is listed in PCAN-View.
When I connect the 2 Channel USB-Pro box, the LEDs shine brightly green and stay on. The device pops up in the device manager and can be used in PCAN-View.
Any clues what might be my issue here?
Post by M.Heidemann » Wed 22. Jul 2020, 15:00
Does the same behaviour manifest on another PC with your PCAN-USB ?
Have you tried other USB-ports, does the behaviour change?
For further support please contact us at support[at]peak-system.com with the full serial number of your PCAN-USB.
Best regards
mb-86
Post by mb-86 » Wed 22. Jul 2020, 15:19
yes it's the same on at least two computers. Changing USB-Ports does not help.
I'll go and check with your support.
Thank you :)
mb-86
Post by mb-86 » Wed 22. Jul 2020, 16:29
The support (Marvin) solved my issue immediately!
Kudos to you!
