I seem to be having some issues while trying to install the chardev PCAN driver. Even when following the manual instructions as-is, I receive errors during modprobe.
Attached is the complete make log. Thank you kindly for your time. This is on a clean Focal installation with no special modification. g++ and libpopt-dev are present.
At the end of sudo make install, /proc/pcan does not exist and sudo modprobe pcan produces errors. Kernel version is 5.4.0-42-generic.
I believe that I have missed something, and I would be very grateful if you could point me in the right direction.
Regards.
fkelava@atomos-linux:~/Documents/peak-linux-driver-8.10.2$ ls
Documentation lib LICENSE.gpl Makefile test
driver libpcanbasic LICENSE.lgpl README
fkelava@atomos-linux:~/Documents/peak-linux-driver-8.10.2$ make clean
make[1]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/driver'
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd pcan.mod.c Module.symvers modules.order .cache.mk
make[1]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/driver'
make[1]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/lib'
rm -f src/*~
rm -rf obj lib obj32 lib32
make[1]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/lib'
make[1]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/test'
make[1]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/test'
make[1]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic'
make[2]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/pcanbasic'
rm -f src/*~ out/*.o *~ *.so.* *.so
make[2]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/pcanbasic'
make[2]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/pcaninfo'
rm -f src/*~ src/*.o ../pcanbasic/src/*~ ../pcanbasic/src/*.o *~ *.so.* *.so pcaninfo.1.0.3 pcaninfo
make[2]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/pcaninfo'
make[2]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/examples'
make[3]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/examples/c++'
make[3]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/examples/c++'
make[3]: Entering directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/examples/python'
rm -f *.pyc
make[3]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/examples/python'
make[2]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic/examples'
make[1]: Leaving directory '/home/fkelava/Documents/peak-linux-driver-8.10.2/libpcanbasic'
*** Host OS Release=Ubuntu v20.04
*** Host machine kernel version=5.4.0-42-generic
*** Driver kernel version=5.4.0-42-generic (5.4.0)
*** Path to kernel sources=/usr/src/linux-headers-5.4.0-42-generic
*** use KBUILD=yes
*** gcc version=9
make -C /usr/src/linux-headers-5.4.0-42-generic EXTRA_CFLAGS="-I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT -Wno-date-time" V=0 modules M=/home/fkelava/Documents/peak-linux-driver-8.10.2/driver
make[2]: Entering directory '/usr/src/linux-headers-5.4.0-42-generic'
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_main.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_fops.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_fifo.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_filter.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_parse.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_sja1000.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_common.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_timing.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcanfd_core.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcanfd_ucan.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_usb_core.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_usb.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_usbpro.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcanfd_usb.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_pci.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcanfd_pci.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_pci_spi.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_pciec.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_isa.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_dongle.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_pccard_core.o
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/src/pcan_pccard.o
LD [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/pcan.o
Building modules, stage 2.
MODPOST 1 modules
CC [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/pcan.mod.o
LD [M] /home/fkelava/Documents/peak-linux-driver-8.10.2/driver/pcan.ko
make[2]: Leaving directory '/usr/src/linux-headers-5.4.0-42-generic'
*** Making pcan libraries
*** gcc version: 9
gcc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls -DPCANFD_OLD_STYLE_API -c src/libpcan.c -o obj/libpcan.o
gcc -shared -Wl,-soname,libpcan.so -o lib/libpcan.so.6 obj/libpcan.o
cd lib/; ln -sf libpcan.so.6 libpcan.so
gcc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls -DPCANFD_OLD_STYLE_API -c src/libpcanfd.c -o obj/libpcanfd.o
gcc -shared -Wl,-soname,libpcanfd.so -o lib/libpcanfd.so.8 obj/libpcanfd.o
cd lib/; ln -sf libpcanfd.so.8 libpcanfd.so
*** gcc version: 9
gcc -DNO_RT -I. -I../lib -I../driver -g src/receivetest.c src/common.c -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -o receivetest
g++ -DNO_RT -I. -I../lib -I../driver -g src/transmitest.cpp src/common.c src/parser.cpp -lstdc++ -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -o transmitest
gcc -DNO_RT -I. -I../lib -I../driver -g src/bitratetest.c src/common.c -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -o bitratetest
g++ -DNO_RT -I. -I../lib -I../driver -g src/filtertest.cpp src/common.c -lstdc++ -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -o filtertest
gcc -DNO_RT -I. -I../lib -I../driver -g src/pcanfdtst.c -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -lpthread -o pcanfdtst
gcc -DNO_RT -I. -I../lib -I../driver -g src/pcan-settings.c -lpopt -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -g -o pcan-settings
gcc -DNO_RT -I. -I../lib -I../driver -g src/receivetest_posix.c src/common.c -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -lpthread -o receivetest_posix
g++ -DNO_RT -I. -I../lib -I../driver -g src/transmitest_posix.cpp src/common.c src/parser.cpp -lstdc++ -lpcanfd -L../lib/lib -Wl,-rpath ../lib/lib -lpthread -o transmitest_posix
*** Making PCANBasic library with FD support (PCAN driver >= 8.0)
*** target=libpcanbasic
*** version=4.3.4
*** PCAN_ROOT=/home/fkelava/Documents/peak-linux-driver-8.10.2
*** gcc version=9
mkdir -p out
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c src/libpcanbasic.c -o out/libpcanbasic.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c src/pcaninfo.c -o out/pcaninfo.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c src/pcanlog.c -o out/pcanlog.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c src/pcbcore.c -o out/pcbcore.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c src/pcblog.c -o out/pcblog.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c src/pcbtrace.c -o out/pcbtrace.o
gcc -fPIC -shared -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -c /home/fkelava/Documents/peak-linux-driver-8.10.2/lib/src/libpcanfd.c -o out/libpcanfd.o
gcc -shared -Wl,-soname,libpcanbasic.so -o libpcanbasic.so.4.3.4 out/libpcanbasic.o out/pcaninfo.o out/pcanlog.o out/pcbcore.o out/pcblog.o out/pcbtrace.o out/libpcanfd.o -lm
ln -sf libpcanbasic.so.4.3.4 libpcanbasic.so
*** Making PCANINFO
*** target=pcaninfo
*** version=1.0.3
*** gcc version=9
gcc src/main.c ../pcanbasic/src/pcanlog.c ../pcanbasic/src/pcblog.c ../pcanbasic/src/pcbtrace.c ../pcanbasic/src/pcbcore.c ../pcanbasic/src/pcaninfo.c /home/fkelava/Documents/peak-linux-driver-8.10.2/lib/src/libpcanfd.c -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I../pcanbasic/src -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -I/home/fkelava/Documents/peak-linux-driver-8.10.2/lib -lm -o pcaninfo.1.0.3
ln -sf pcaninfo.1.0.3 pcaninfo
*** Making PCANBasic C++ examples
*** g++ version=9
*** PCANBASIC_ROOT=../../pcanbasic
g++ -I../../pcanbasic -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -DNO_RT src/pcanwrite.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcanwrite
g++ -I../../pcanbasic -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -DNO_RT src/pcanread.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcanread
g++ -I../../pcanbasic -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -DNO_RT src/pcaneventread.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcaneventread
g++ -I../../pcanbasic -I/home/fkelava/Documents/peak-linux-driver-8.10.2/driver -DNO_RT src/pcaneventwrite.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcaneventwrite
make[3]: Nothing to be done for 'all'.
fkelava@atomos-linux:~/Documents/peak-linux-driver-8.10.2$ sudo make install
[sudo] password for fkelava:
Info: /lib/modules/5.4.0-42-generic/misc exists.
mkdir -p /usr/lib
cp -d lib/* /usr/lib
if [ -d lib32 ]; then \
mkdir -p /usr/lib32; \
cp -d lib32/* /usr/lib32; \
fi
mkdir -p /usr/include
/sbin/ldconfig
cp receivetest transmitest bitratetest filtertest pcanfdtst pcan-settings receivetest_posix transmitest_posix /usr/local/bin
cp libpcanbasic.so.4.3.4 /usr/lib/libpcanbasic.so.4.3.4
ln -sf /usr/lib/libpcanbasic.so.4.3.4 /usr/lib/libpcanbasic.so.4
ln -sf /usr/lib/libpcanbasic.so.4.3.4 /usr/lib/libpcanbasic.so.0
/sbin/ldconfig
cp pcaninfo.1.0.3 /usr/local/bin/pcaninfo
make[3]: Nothing to be done for 'install'.
fkelava@atomos-linux:~/Documents/peak-linux-driver-8.10.2$ sudo modprobe pcan
modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe --ignore-install pcan' for module pcan: retcode 1
modprobe: ERROR: could not insert 'pcan': Invalid argument
