[PCAN Driver for Linux v8]"Unknown symbol in module" error when insmod is used instead of modprobe
vijayendranss
Post by vijayendranss » Fri 11. Sep 2020, 05:09
I use PCAN Driver for Linux v8.
By seeing the manual, i completed till
sudo modprobe pcan
When no devices connected to my PC, i execute
lspcan -T -t -a
No devices are displayed.
In this stage, i dont want to use modprobe command.
Instead, i want to use insmod command.
Reason for this i am asking is because, i want virtually install(display) the devices under /dev regardless of the actual devices connected or not.
I tried using another different LKM (Linux Kernel Module) application which gives the output as XX.ko.
Purpose of this LKM is to install the devices virtually.
I tried loading the ko file of this LKM. It installed succesfully.
Hence i want to use insmod for our PCAN Driver too. I am thinking it will get loaded.
I tried using as below
root@rosmaster:/home/usr/work/peak-linux-driver-8.10.2/driver#insmod pcan.ko
insmod: ERROR: could not insert module pcan.ko: Unknown symbol in module
I understand pcan.ko is dependent on other modules like
  • pcmcia,
    parport,
    i2c-algo-bit
Please suggest me how to solve this issue ?
Or is there any way to virtually load the devices using probemode itself ?
vijayendranss
Re: [PCAN Driver for Linux v8]"Unknown symbol in module" error when insmod is used instead of modprobe
Post by vijayendranss » Fri 11. Sep 2020, 06:46
I tried as below given in the manual also.. But same error..
root@rosmastar:/home/ams_user/work/vijay/peak-linux-driver-8.10.2/driver# modinfo pcan.ko | grep -e "^depends:"
depends:        pcmcia,parport,i2c-algo-bit
root@rosmastar:/home/ams_user/work/vijay/peak-linux-driver-8.10.2/driver# modprobe pcmcia parport i2c-algo-bit
root@rosmastar:/home/ams_user/work/vijay/peak-linux-driver-8.10.2/driver# insmod pcan.ko
S.Grosjean
Post by S.Grosjean » Fri 11. Sep 2020, 09:36
Please check what are the missing symbols with:
$ dmesg
vijayendranss
Post by vijayendranss » Fri 11. Sep 2020, 11:15
@S.Grosjean
This is the output of dmesg..
[15454.116955] pcan: Unknown symbol pcmcia_disable_device (err -2)
[15454.116972] pcan: Unknown symbol i2c_bit_add_bus (err -2)
[15454.116987] pcan: Unknown symbol pcmcia_unregister_driver (err -2)
[15454.117031] pcan: Unknown symbol pcmcia_loop_config (err -2)
[15454.117072] pcan: Unknown symbol pcmcia_request_io (err -2)
[15454.117101] pcan: Unknown symbol pcmcia_register_driver (err -2)
[15454.117111] pcan: Unknown symbol pcmcia_enable_device (err -2)
[15454.117123] pcan: Unknown symbol pcmcia_dev_present (err -2)
[13961.278298] pcmcia: unknown parameter 'parport' ignored
[13961.278299] pcmcia: unknown parameter 'i2c-algo-bit' ignored
[13972.657876] pcan: Unknown symbol i2c_bit_add_bus (err -2)
[13994.485964] pcan: Unknown symbol i2c_bit_add_bus (err -2)
[14611.501569] pcan: Unknown symbol i2c_bit_add_bus (err -2)
S.Grosjean
Post by S.Grosjean » Fri 11. Sep 2020, 11:35
As said by dmesg:
parport and i2c-algo-bit are handled as *PARAMETERS* to pcmcia module, which is coherent with your erroneous command line:
So, truth is definitively in "man modprobe"...
vijayendranss
Post by vijayendranss » Fri 11. Sep 2020, 11:40
@ S.Grosjean
Thanks...
Can you suggest me solution if possible..
I followed as per the manual PEAK has provided.
S.Grosjean
Post by S.Grosjean » Fri 11. Sep 2020, 11:58
Of course:
$ man modprobe
