Any help welcome!
I'm attempting to get a PCAN ethernet-CAN gateway going. The CAN->UDP direction is working, but not the UDP->CAN direction. I've tried using the "host_tx" utility I found on this site. tcpdump indicates the UDP packet going to the correct destination & correctly formatted as far as I can tell from the documentation (and comparing with traffic in the other direction).
Listen-only is off.
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on neta, link-type EN10MB (Ethernet), capture size 262144 bytes
23:50:57.602108 IP 192.168.0.1.36626 > 192.168.0.4.3240: UDP, length 36
0x0000: f073 ae00 4032 3cec ef44 b61b 0800 4500
0x0010: 0040 69d8 4000 4011 4f7f c0a8 0001 c0a8
0x0020: 0004 8f12 0ca8 002c 8193 0024 0080 0000
0x0030: 0000 0000 0000 0000 0000 0000 0000 0008
0x0040: 0000 0000 0604 4000 3004 0000 0000
But there appears to be no activity on the CAN bus.
Any ideas?
Attaching my device configuration.
Failing to get PCAN to transmit on CAN
poi_config.ini
- Device config.
- (6.31 KiB) Downloaded 1597 times
- Hardware Development
Re: Failing to get PCAN to transmit on CAN
you have to switch off handshaking for the LAN->CAN route if you want to communicate with you own application (see chapter 1.3 ff in developer documentation.
BR,
Stephan
BR,
Stephan
Thanks for the prompt answer. I'll try that as soon as I get a chance.
