I'm getting an invalid handle error.
result = XCPApi.Connect(m_XcpSession, 0, msg, (ushort)msg.Length);
XCPApi.Connect seems to be working successfully but when I use same handle for AddSlaveOnCan, I get "The given handle is invalid" error. Variables are as below.
private TXCPChannel m_XcpChannel;
private TXCPHandle m_XcpSession;
private TXCPProtocolLayerConfig m_XcpProtocolConfig;
private TXCPTransportLayerCAN m_XcpSlaveData;
result = XCPApi.AddSlaveOnCAN(m_XcpChannel, m_XcpSlaveData, m_XcpProtocolConfig, out m_XcpSession);
Can you help me please? Thanks in advance.
Invalid handle
Re: Invalid handle
Please make sure that you have the latest PCANBasic API and PCAN-XCP API Installed.
PCANBasic API:
https://www.peak-system.com/fileadmin/m ... -basic.zip
PCAN-XCP API:
https://www.peak-system.com/fileadmin/m ... AN-XCP.ZIP
Furthermore, is there a XCP-Slave available on the Bus and is it answering?
Please also check, if the Example appliaction in the PCAN-XCP package works correctly.
(You should see the Slave respond after clicking "Connect Slave")
PCANBasic API:
PCAN-XCP API:
