Licence issue
Locked
yrt38
Licence issue
Post by yrt38 » Wed 30. Jun 2021, 15:52
I use PCAN explorer with "ImportDB" plugin.
Since I used it with a dongle without "ImportDB" licence (switch of the PcanExpl.lic file), PCAN explorer is not able to read my project with a .DBC, it cannot see the signals, although I use the good dongle (with switch to the good PcanExpl.lic file).
How can I slove this issue ?
M.Gerber
Design & Documentation
Re: Licence issue
Post by M.Gerber » Thu 1. Jul 2021, 12:22
In PCAN-Explorer, go to Tools > Add-in Manager and make sure that the list entry CANdb-Import is checked.
Please give a short feedback if this has helped.
Kind regards
Mark
Re: Licence issue
Post by PEAK-Support » Thu 1. Jul 2021, 21:10
TIP:
Convert the db to SYM and replace the dbc with the converted SYM.
Then all PE6 Versions could open it and you do not need to convert the dbc every time you startup the Project.
yrt38
Re: Licence issue
Post by yrt38 » Mon 5. Jul 2021, 11:22
I used the import to SYM, but it is necessary at each .dbc modification.
But effectiveley, the check box was not checked in "Add-in manager". After checked it, ihen it works fine.
Thanks a lot.
Re: Licence issue
Post by PEAK-Support » Tue 6. Jul 2021, 13:24
OK - Problem solved!
Locked
