I'm using the PCANBasic dll in a windows program. I'm using, as suggested, the SetEvent interface to set an event when a message is received. Is it possible to do the same in transmission? As far as I understood the CanWrite interface use a queue mechanism. Is it possible to rise an event at end of transmission and know which message was sent?
thanks
Michele
end of transmit event
Re: end of transmit event
There is not Transmit-Event implemented in PCANBasic, having
the transmission event raised therefore is not possible in PCANBasic.
If you do not fill the queue faster than the frames can be written by the hardware, you can
be quite sure that the last frame you pushed to queue is the last one that was written.
hello,
thanks for your answer. My question was for timestamping purposes.
thanks
Michele
thanks
Michele
in this case you could consider taking a look at the PCAN-Developer package:
https://www.peak-system.com/PCAN-Develo ... .html?&L=1
The PCAN-API 4 included in the Developer package allows for Messages have future
timestamps, which will have the messages transmit once the timestamp is reached.
If you only want to receive the timestamp for a transmit-message, you can also take
advantage of the self-receive feature of PCAN-API 4.
