I am having some issues setting up the correct routing to be able to access CAN data via a socket. I have the "handshake" disabled per the instructions in section 1.3 of [1]. What would be the correct IP address for STEP 4 of (Routing » Manage Routes » Edit Route)? It says to 'Enter the IP address of the device that should act as the receiver for this route.' Is this a separate IP address that must be routed? Any information about how to utilize the "Destination" connection would be appreciated.
Thanks!
[1] https://www.peak-system.com/produktcd/P ... on_eng.pdf
Setting up IP routes for PC via Sockets
poi_config.ini
- (2.96 KiB) Downloaded 1540 times
- Hardware Development
Re: Setting up IP routes for PC via Sockets
Hi Austin,
this is simply the IP address of the destination, e.g. the PC you have opened your socket / running your our application to receive the data.
BR,
Stephan
BR,
Stephan
