Debugger for custom firmware
c.litke
Post by c.litke » Thu 11. Nov 2021, 13:08
Hi PEAK Forum,
I am currently developing custom firmware for the PCAN-Router Pro. I am trying to keep track of multiple variables I have set up to monitor my incoming CAN-Messages.
Is there some sort of (live-)debugging utility? Ideally similar to VS Code, allowing you to set up breakpoints and inspect memory? Or any other sort of live monitoring that is supplied by PEAK?
Litke
Re: Debugger for custom firmware
Post by PEAK-Support » Thu 11. Nov 2021, 15:12
We are sorry - but we do not offer any Debugging Tool for the open source environment SDK of the Router Pro Device.
You could use CAN Frames, sending out internal Data as Remote Information, for your development.
