I have a question about Peak Router Pro.
I know there are two ways to configure a Peak Router Pro: Creating a configuration using PPCan-Editor, or flashing the firmware with Pcan-Flash.
My question is:
After a firmware flash using Pcan-flash, is there any way to load a configuration again with PPCan-Editor?
Or it won't because the flash process deletes something internal in the Peak Router so that you can't configure the device with PPCan-Editor anymore?
Thanks.
Load configuration with PPCan-Editor after firmware flash
Re: Load configuration with PPCan-Editor after firmware flash
You have already received an answer to your request via email,
please check your email inbox.
To quote the email:
send via email, this only creates additional work for the Support-Team.
To quote the email:
Please do not contact us via the forum if the same request was alreadyUsing PEAK-Flash you may upload -any- software to the device,
regardless whether it's your own (self -written) or our official PEAK software (v1.15.1 at the moment).
But:
Only the official PEAK software is capable of being configured with PPCAN-Editor,
as it is mainly a collection of loose modules that need to be linked together to fulfil a specific function.
This "interconnecting" is what the configuration/the editor does.
Your self-written software will -not- support this concept,
instead it straightly does what you programmed ...
